1985 Ram Charger wheel studs and nuts
Hi there guys, Someone tried to nick my wheels the other night and has caused a bit of damage to the front studs and taken three wheel nuts.
Can someone tell me if the studs on the front are different to the studs on the back and possibly give me some part numbers and where to order some new ones from. Since the ar#$%^le has taken three wheel nuts I might as well purchase a set of four locking nuts. Cheers Paul from New Zealand |
Thats pretty shitty for someone to do, same front and rear & a dealer or your local parts store will prob. have them - I think they are a pretty standard studs so you should not have too much trouble finding them, good luck man
I believe that they are either 1/2" or 9/16". Not sure if the fronts and rears are the same as the front should have disc and the rear is drum.
There is a forum called Ramchargercentral.com (I think) and they are very knowledgable on all years of the Ram Charger.
