1985 Ram Charger wheel studs and nuts
Old May 23, 2010 | 08:00 PM
Blownvh's Avatar
Junior Member
Hi there guys, Someone tried to nick my wheels the other night and has caused a bit of damage to the front studs and taken three wheel nuts.
Can someone tell me if the studs on the front are different to the studs on the back and possibly give me some part numbers and where to order some new ones from. Since the ar#$%^le has taken three wheel nuts I might as well purchase a set of four locking nuts. Cheers Paul from New Zealand
Old May 23, 2010 | 08:06 PM
Sgt. Veteran's Avatar
Old As Dirt
Thats pretty shitty for someone to do, same front and rear & a dealer or your local parts store will prob. have them - I think they are a pretty standard studs so you should not have too much trouble finding them, good luck man
Old May 24, 2010 | 03:20 AM
I believe that they are either 1/2" or 9/16". Not sure if the fronts and rears are the same as the front should have disc and the rear is drum.
Old May 24, 2010 | 04:17 AM
sweeperking's Avatar
Check this link out it may help.
http://www.rockauto.com/catalog/rafr...145774-2242363
Old May 24, 2010 | 04:52 AM
There is a forum called Ramchargercentral.com (I think) and they are very knowledgable on all years of the Ram Charger.
Kowalenko93
Dec 17, 2013 03:24 AM
JETBLU
Oct 4, 2011 08:14 AM
Adamtsi
Feb 16, 2011 04:42 PM
nailbender
Jan 4, 2010 07:28 PM
Sidedraft
Nov 27, 2007 03:03 AM
