440 distributor question
Old Jun 7, 2010 | 03:34 PM
2002ram440's Avatar
i have a 440 from a 78 motorhome with mild cam running 10.5:1 comp. i can not get the advance timing right. i was told by a Mopar guy that i need to be 28 to 32 degrees total advance but i am getting about 45. i have chnaged the pick up coil and the vacuum advance. i have changed the springs adn still too much. any ideas?
Old Jun 7, 2010 | 04:08 PM
Barfly's Avatar
Points or electronic ignition?
Old Jun 7, 2010 | 04:14 PM
2002ram440's Avatar
electronic
Old Jun 7, 2010 | 04:33 PM
Barfly's Avatar
I just learned this recently myself, and more or less was warned against trying the adjustment. But on distributors with electronic ignition there is an adjustment screw inside the vacuum advance unit. You pull the hose off and insert a 3/32" allan wrench to adjust the amount of advance the diaphragm gives.
One Second I will try and find the reference........
Here it is see the Electronic Ignition part of the article.
And remember the guys that responded to my question kinda warned against fiddling
with this.
Joe.
mrzods13
Jun 16, 2014 03:05 PM
newto440
Apr 13, 2014 07:11 AM
jjm
May 29, 2012 02:42 PM
lynchroad
Jan 23, 2011 12:38 PM
valleyofthesuns
Sep 24, 2008 09:56 AM
