Mopar Forums (/forums/)
-   72-93 Dodge Trucks (https://moparforums.com/forums/f96/)
-   -   440 Engine Swap (https://moparforums.com/forums/f96/440-engine-swap-24455/)
jibs1723 Feb 17, 2022 10:50 AM
440 Engine Swap
Hi all I am putting a 1968 440 with an NP435 into a 1979 W400 that had a 360. I am replacing the NP203 with an NP205 transfer case and was using the stock truck motor mounts that came out of a 1977 D300. I just went to drop the motor in and it appears to be sitting too far back. Hard to tell as I have the cab off the truck for body work. Is anyone aware of either a different motor mount used in the 4wd big block trucks or transmission cross member? The cross member is from the small block truck. Thanks
https://cimg5.ibsrv.net/gimg/moparfo...e26bc7be44.jpg
https://cimg9.ibsrv.net/gimg/moparfo...cd7a45cd48.jpg
Lostviking Feb 17, 2022 03:34 PM
Did you check online to see if the trucks used the same part number?
RacerHog Feb 18, 2022 08:56 AM
Wow... I have no idea....
Looks like from that angle, that the mount needs to be mounted on the front block ear tabs!!! But i'm not sure if that would fit that way?
Can't say that i have see any mounts with that much offset....
