72 d100 instrument panel
Old May 5, 2020 | 01:22 PM
Nathanael Hull's Avatar
Hey guys quick question for you all regarding the 72 d100 instrument panel. I recently replaced the firewall bulkhead connector and when i did that i also worked on the ignition switch, turn signal cam, and instrument panel. Everything is working now for the most part. When i took apart the instrument panel i noticed the back had all the bulbs and sockets missing. So i bought sockets and bulbs (went with 194 LEDs) and put them all in. Put the panel back in and turned on the headlights with key in accessory and no lights come on. The light on the gear selector come on but nothing in the dash. Speedo is the only thing that works. Any tips or things i should check?
Any info is appreciated, Thanks
Old Jul 19, 2020 | 08:01 AM
dodgewade's Avatar
No sure if you got your opportunity fixed, but LED's are positive and negative sensitive. Positive must but be 12v and negative should be ground.
txbob
Dec 9, 2018 10:38 PM
dgbcharger
Apr 22, 2013 04:36 PM
1sttvbn
Aug 25, 2012 08:51 PM
Leem
Apr 15, 2012 10:46 PM
emmoe
Jun 27, 2011 05:53 AM
