75-78 Dodge
Old Dec 11, 2021 | 04:34 AM
VIOLETTYLER18826's Avatar
75-78 Dodge
Hi, im rebuilding my 76 dodge w200. It came with the 360 with the 727(crankshaft is broken) I also have a 318 im partly threw redoing seals on. Just recently picked up a parts truck 78 w200 with a 383 (ran block number) in it and would rather put that in. What do i need to get in order to do so? New bellhousing?(posible the bellhousing from the parts truck will fit current tranny)Conversion kit? Or just go get a tranny(swap to manual)/rebuild the parts truck tranny. I live in ak so my options are slim.
Thanks Violet
Old Dec 11, 2021 | 09:49 AM
Big Block Engine / Big Block Transmission
Small Block Engine / Small Block Transmission
Six Cylinder Engine / Six Cylinder Transmission
You Cant mix and Match..
So if you have all the part for the 78>>>>> I would swap it all over...
K-Member / Engine / Transmission / Transmission Brackets /
For the most part after working out odds and ends, you may need to get a driveshaft to fit.
Good Luck... Keep us posted...
Old Dec 11, 2021 | 04:12 PM
this is on automatic transmissions the manual transmission you need a different bellhousing....
Jacob Bernier
Feb 18, 2020 04:31 PM
Hilltop1
Sep 25, 2017 02:17 PM
rattruck440
Dec 26, 2013 09:23 PM
mjones83
Nov 18, 2012 01:11 AM
dbear
Nov 19, 2011 04:25 AM
