87 d150 losing power to coil when cranking
Old Dec 14, 2019 | 12:26 PM
87slant6's Avatar
I have a 87 d150 with a slant 6 and a manual transmission. When I first crank the truck I get maybe 1 to 2 sparks then nothing. Hooking up a volt meter shows its getting power to the coil at first but something is killing the power when its cranking. I ran a jumper wire from the battery to the ignition coil and it fired right up. Once it's running you can take off the jumper wire and it will stay runnin . Only loses power when its cranking. Is there some kind if safety switch that would be doing this? Thanks for any help
Kevin71
Jun 3, 2015 09:04 AM
dmartin1
May 6, 2013 05:40 AM
Lana
Aug 14, 2012 09:45 AM
twisted68
Jul 13, 2012 07:46 PM
ssdart225
Feb 25, 2011 05:18 PM
