dana 44 stone shield lip seal - Forsheda v-ring
4 Attachment(s)
When I removed my front drive axles to replace my steering ujoints. I notice they had an odd rubber "v-ring" seal on them. Molded on them was " Forsheda 38415". I set out to get replacements since mine where old and weathered. I couldn't find anything based on my application alone (1977 Dodge W200) so, I tried using the information molded into the rubber itself. I cam across a website that crossed referenced the number over to Napa 400700. So, I ordered two.
They fit on the stone shield just fine. However, when I starting putting the hub/bearing assembly back together I notice these seals didn't have sufficient clearance and interfered with the hubs being able to turn freely. So I ended up removing them (destroying them in the process) to correct that problem. I'm not sure what went wrong, but I do have some ideas.
I was able to find one other online discussion about this over at ramcharger central. http://ramchargercentral.com/vehicle...e-shaft-seals/ Has anyone here encountered this problem before? |
https://ramchargercentral.com/vehicl...heel-bearings/
PowerWagonPete @ ramchargercentral Glad I finally found some info on this deal. |
