door hinges like duct tape...
Old Apr 20, 2010 | 06:26 PM
Hollonator's Avatar
Member
The lower door hinges on my 1979 Dodge W100 are terrible, wore slap out. And my luck for finding new ones for less than $80 a piece is bout the same luck I've had with the lottery, hence why I'm not willing to spend $80 on a door hinge...The lower hinge on the passengers side can just get a rebuild kit but I can't rebuild the lower driver's side cause it ain't even got all the parts! Any suggestions? Thanks.
Old Jan 2, 2011 | 11:32 AM
Beerstop's Avatar
junk yard
or mopar only out in michigan
Old Jan 4, 2011 | 12:33 AM
67Polara's Avatar
try taking them off another year ram ? might be cheaper...
Old Jan 4, 2011 | 02:31 AM
Only way around it (cheaply that is) is to buy a hinge off of a donar truck.
Old Jan 4, 2011 | 02:47 AM
BuckNeccid's Avatar
Pull the hinges, remove the pin, weld the hole up. Re-drill the hole the size needed and replace the pin with one out of any of the door hinge rebuild kits?
Old Jul 2, 2011 | 05:22 PM
trivium's Avatar
your not looking for the hinge, your looking for the hinge pins and bushings unless i misunderstood the problem, look on ebay and you will need two people to change them.
Nathan talley
Feb 11, 2014 03:49 PM
MilesP
Jan 25, 2014 05:59 PM
bobfist
Jun 22, 2013 04:16 PM
157forj
Oct 14, 2012 10:50 PM
cudaracer
Aug 4, 2011 10:38 PM
