Grille question
Old Mar 30, 2021 | 08:56 AM
Pat80D100's Avatar
Grille question
Will a 72-76 grille fit in a 80 round headlight truck?
Old Apr 4, 2021 | 12:07 AM
Tau511's Avatar
Those grilles are really different. If all you want to replace is the grille it won't work. But if you are up for swapping the lights and everything else then it should be fine (if you're asking if it will all bolt up to the rad support for example).
If you are just asking about the center section, the answer is no - that part is not interchangeable as far as I know. You'll need to swap more parts (which is easy to do).
70roadrunner383
Oct 16, 2014 09:04 AM
dvss1
Jan 25, 2011 11:01 PM
Hollonator
Feb 23, 2010 11:20 AM
Mr.Duster
Apr 11, 2009 11:55 PM
78trailduster
Feb 15, 2009 07:02 AM
