Manual transmission
Will the A833 and np435 bellhousings interchange?
I don't believe so.
We did something like this, the trans face is different, larger flywheel (143T) with groove on inside of bellhousing (smallblock), different types of clutch actuation depending on what model, it was a real shit show, but I made it work in the '92.
Dan which way were you going, what bellhousing to what bellhousing or was it a transmission swap?
We put an 833 on the truck bellhousing. Made stuff to bolt the different bolt pattern. I think Shawn used a hydraulic cylinder to move a mechanical fork which I made stuff for and a hydraulic pedal. I think that was it. I think he did this to use an O.D. Trans we had and a new 143 440 flywheel, pressure plate and disc I had from years ago. Did I ever tell you we’re cheap. |
I've kinda noticed......
