Manual transmission
Old Jul 19, 2018 | 05:39 PM
Gene75D100's Avatar
Manual transmission
Will the A833 and np435 bellhousings interchange?
Old Jul 20, 2018 | 07:56 AM
I don't believe so.
Old Jul 20, 2018 | 02:06 PM
We did something like this, the trans face is different, larger flywheel (143T) with groove on inside of bellhousing (smallblock), different types of clutch actuation depending on what model, it was a real **** show, but I made it work in the '92.
Old Jul 20, 2018 | 02:43 PM
Dan which way were you going, what bellhousing to what bellhousing or was it a transmission swap?
Old Jul 20, 2018 | 04:57 PM
We put an 833 on the truck bellhousing. Made stuff to bolt the different bolt pattern. I think Shawn used a hydraulic cylinder to move a mechanical fork which I made stuff for and a hydraulic pedal. I think that was it. I think he did this to use an O.D. Trans we had and a new 143 440 flywheel, pressure plate and disc I had from years ago. Did I ever tell you we’re cheap.
Old Jul 20, 2018 | 05:25 PM
I've kinda noticed......
Ryanesch127
Jul 16, 2018 06:25 PM
Jon
Dec 1, 2012 09:20 PM
a0m397x
Nov 8, 2010 02:22 PM
timmie124
Jul 24, 2010 05:58 AM
tish
Oct 1, 2008 01:57 PM
