Truck won't crank with ignition switch
Old Jul 7, 2021 | 06:20 AM
myraus's Avatar
Well, my 1975 D100, with a 360/727 combo, will not crank when the ignition switch is turned. It is making all the right connections in the system, even to the starter relay. That relay has also been replaced, but to no avail to get it to crank.
The starter only cranks when the two big terminals on the relay are jumped. What should I look at next? Replace the starter?
Old Jul 7, 2021 | 09:23 AM
if that's the case the solenoid (the thing youre jumping) is likely bad. a trip to autozone and a 20 dollar bill should solve that.
Old Jul 9, 2021 | 05:36 AM
Check the Neutral safety switch
66FuryBoy
Jun 13, 2022 08:48 PM
Plymouth361
Apr 16, 2021 01:51 PM
rcknrolfender79
Apr 9, 2015 08:32 AM
theDeathVegetable
Feb 28, 2013 05:21 PM
AZDODGEMAN
Apr 11, 2011 12:39 PM
