Viper Roadrunner
Old Apr 6, 2014 | 02:34 PM
christineman's Avatar
Viper implant
Wondering if anyone put a new Hemi or viper Engine in a mopar 60s or 70s. If u did is like to hear from u please
Mel@moparmel.com
Old Apr 6, 2014 | 07:30 PM
Kevman89's Avatar
Working on it at the moment, you need to cut the trans tunnel, and modify the torsion bar / transmission cross member to fit the T-56, you need a tubular K-member.. The K-member requires the motor mounts to be moved forward four inches..
You can no longer fit a Mopar Steering box, you have to go non powered rack and pinion..
Anything after that, drive shaft, rear end, fuel, electrical, isn't a big deal..
You can still use the torsion bars, and have a comfortable spot for your shifter..
Check out my thread in member projects, 1972 Charger from Windsor Ontario.
Old Apr 6, 2014 | 09:38 PM
Like said just depends on how much work and money you want to spend. A new hemi is doable too but still needs custom work
trev0006
Feb 8, 2013 03:07 PM
blue 68 gts
Dec 19, 2011 06:25 PM
Liu Kang
Dec 2, 2010 08:29 AM
dartcuda
Oct 30, 2008 07:01 PM
buttslapper
Oct 1, 2007 06:32 AM
