Thread: Opinion Needed
View Single Post
Old 08-01-2008, 02:58 AM   #7 (permalink)
Ph.D in wheelinology
Send a message via AIM to 78D200
Make sure that teh heads that you are getting are for a Magnum motor and not a LA motor. The two will be different. Edelbrock does recommend a cam to go with their heads most of the time, so check out their website. Also look into getting a good quality set of headers.
Since you will be going with a larger throttle body and cam, look into getting your computer reprogrammed so that way it knows how to compensate for the performance parts that you are installing.
__________________
Tim and Heather
1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds
jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/
78D200 is offline   Reply With Quote
