318 cuts out really bad at times
Old Aug 22, 2008 | 06:02 PM
cide's Avatar
hey guys i have a 92 dodge ram 4x4 and some where alongs the lines of when we rebuild the trans and got it straight the motor is playing trixs .there was a lifter tapping so we replaced it. and now after it runs for 20 pr 30 min. it goes to loading up or something so i replace the map sensor fill fiter oxgen sensor and it still does this and i also remove the Air flow sensor and clean all the carben off of it.has a new distriburter cap . could it be a intake leak or what do you guys think .[and the help on the trans was really great got er fix right on up thanks]
Old Aug 23, 2008 | 05:31 AM
cide's Avatar
codes 12,22,55 and i think 12 has sometthing to do with batter being dicountected and 22 votage to high at cooling sensor and 55 end of reading . iguess these is correct. i,ll will replace the air flow today .what about the pressure regulater could it cause this i have left out one thing that mite be important when it start acking up you can mass the gas and its like its starven for fuel .the fuel pump has been replace maybe a year and half ago so i hopen its still good
Old Aug 23, 2008 | 02:57 PM
cide's Avatar
hey guys i replace the mass idle air flow sensor today and it seems to be loading up still have to mash the gas peddle to the floor to get it to crank then runs really crapy scips and won't take the gas and its idles kind of high at times and when in gear you can,t stomp or mash the gas padle hard for it won't take the gas.
Old Aug 28, 2008 | 05:41 PM
cide's Avatar
ok fuel pressure regerlator didn,t fix it either so what the chances of the alumin intake shernken when it get hot .would this cause it to suck air around the gasket if it didn't get a good seal when it was replace,d. causeing it to load up on the gas
Old Sep 8, 2008 | 08:47 AM
Monacoman's Avatar
easyest way to check it spray quick start around the intake and if the engine starts to rev high its a intake leak and can get a close area of where the leak is coming from
440Aspen
Jun 1, 2015 02:07 PM
kingsrex
Mar 9, 2012 11:02 AM
1966sportfury
May 30, 2010 07:59 PM
Morrigan_Aria
Dec 8, 2009 03:13 PM
44072Charger
May 2, 2008 10:01 AM
