318 swap
318 swap
I have a 1974 Dodge Charger and i was wondering what year 318 will fit in my car without much change? Im thinking about getting a 1967 318 to swap but i wanna know if itll swap straight through.
Somewhere around 67 --68 is when the crank register changed. Older (273) used a small snout register for the torqueflite, if that's what you have. If you have a stick, regardless of year, the pilot bushing hole may be undersized -- not finished machined--and some were not deep enough
So I'm going to say 68 / later. You need a front sump pan, IE not a rear sump out of a pickup, van, motor home.
What was originally in the car?
