440 build
Old 12-26-2008, 08:50 AM
I would definetly get a purple shaft cam. Those cams seem to work extremely well. As for which one to go with..... I can't tell ya there (never been real god with picking out cams for other people. I would upgrade to power brakes though. As for the stall convertor, If you are going to be driving it a lot I would go with a 2000-2300 RPM stall converter. If you are going to be doing more racing, then go with a 2700-3000 RPM stall convertor.
Old 12-26-2008, 10:14 AM
whatever cam you choose, pick one that will take advantage of our power range and your torque
i faced a similar problem, and i picked a good cam
i'll look for the numbers for you
Old 12-27-2008, 05:36 AM
I deal with a guy that runs a local performance shop around here and he has run a couple of those. Guys that build fords love them, and we all know about fords.
I'd stick to purple shaft cams or comp cams as they have always been real good for mopars. I wouldn't bother with edelbrock for cams anymore. Their last cam left a bad taste in my mouth. I love the intakes and carbs though.
Old 01-21-2009, 02:19 PM
how did it turn out?
Old 01-21-2009, 09:13 PM
challenger's Avatar
little late but you would be good to go with a P S # p4452993 with 280-280-60x .474lift @ center L of 110 degree ...............let us no what the one you got does for you k
Old 01-21-2009, 09:16 PM
challenger's Avatar
that 533 might be just a bit much for what rear you are running and you will have to get a good stall to make it not bog at the line but like i said let us no k
68 Sat
10-12-2009 07:56 AM
69coronetkyle
08-04-2009 02:22 PM
78machowagon
05-19-2009 04:43 PM
muggsy
02-04-2009 05:39 PM
Quick Reply: 440 build
