68 Satellite map light wiring and Radio
Old 05-13-2009, 02:05 PM
Junior Member
68satellite's Avatar
Question 68 Satellite map light wiring and Radio
I have a 68 Satellite that did not have a map light in it. I would like to install one. I pulled off the blank plate and could not see any existing wiring to connect it to. Should it be there or do I need to run wire. Also the light in the radio is not working. Where should I start with that? Thanks Ken.
Old 05-13-2009, 02:30 PM
scotts74birds's Avatar
The dome light , if equipped should be a pink wire and a yellow wire. These are on the same run as the left and right pocket panel lights and the trunk light. Might be an unused connector under the dash with these wires.http://www.mymopar.com/downloads/196...oadRunnerA.JPG I think the radio light is internal and is just a bulb.
trevorrichland
11-17-2013 09:17 PM
rgdodson54
12-22-2012 08:09 PM
allcore1@hotmail.com
11-27-2012 12:22 PM
mr.300
02-12-2012 11:33 AM
Daytona45
08-22-2009 10:33 PM
Quick Reply: 68 Satellite map light wiring and Radio
