dana 60
Old 10-13-2009, 03:32 AM
That would be a D60. Dodge/Chrysler/Plymouth never used a D44 as a rear axle in cars, only in the 1/2 ton trucks. A D44 wouldn't hold up behind a 440 motor.
Old 10-13-2009, 02:30 PM
you have a 440?
is it a 4 speed car?
Old 10-13-2009, 04:43 PM
rr69half6bbl's Avatar
a little hlpfull hint on dana diagnosis. look at the lower brace webbing on the pass. ide of the center section. it will be cast on the brace what it is. 60,70,44, etc.
Old 10-14-2009, 03:56 PM
is this rear end on your car now?
Old 10-15-2009, 03:28 AM
Its not a 7.25, 8.25, 8.75, 9.25 or 9.75 rear axle. Only other axle that Chrysler used that I know of is the Dana 60 in the cars.
That does look like a D60 by the size of the diff cover bolts too. There are no tags on it or like rr69half6bbl said have you looked at the webbing?
Old 10-22-2009, 04:12 PM
the dana 60 and what was called the corprate dana look identical, until you look at the webbing you cant tell, they both have 12 bolt rear covers. the corprate is a 9 1/4 and the dana is a 9 3/4 ring gear.
B-man
01-04-2009 04:53 PM
phatdak18
01-03-2009 07:57 AM
edwin 440
11-18-2008 05:19 PM
mopar nate
11-11-2008 01:14 AM
499coronet
02-18-2007 12:48 PM
Quick Reply: dana 60
