Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > B-Body
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 02-24-2008, 10:25 AM   #1 (permalink)
64fury
64fury's Avatar
Engine offset??
Is it an optical illusion or is the engine (383) on my 64' Plymouth Sport Fury offset a few inch's to the right in order to clear the stearing box? Or do I have a problem with my engine mounts?
__________________
58' Triumph TR-3A
72' MGB-GT
64fury is offline   Reply With Quote
Old 02-24-2008, 12:57 PM   #2 (permalink)
440roadrunner
Senior Member
It's been a long long time since I've worked on my 64, by my recollection is the same as what you "see." If you had a mount problem, the engine would probably be moving around under torque and causing other problems, like shift linkage binding, noise and banging, etc.
440roadrunner is offline   Reply With Quote
Old 02-27-2008, 12:58 PM   #3 (permalink)
mopar kid67
Junior Member
offset
no you are not seeing things, I have a 1967 coronet 500 it was an original 318 2barrel, I bought the car when i was 15 and shortly after the tranny went out on me so I decided to put in a new trans and a 360, the 360 had a high rise aluminum intake so I got a second hood and cut a hole in it so the air cleaner would clear and had to cut the hole offset because the steering comes out just far enough that the motor mounts are moved over.
mopar kid67 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
