Removing the cam
#31
ya, when you try to rush things, that is when you make mistakes
when i was putting my engine back together, i forgot the oil slinger behind the timing cover. so, i had to take it all back off and the gaskets ripped but, at least i caught myself before i put my engine back in
#32
on
I read about the oil slinger, but did not see one when I pulled the cover off, which was the first time off since 77 I believe. I will be pulling it off so I can put one in if need be, all I changed or saw in that area was the oil seal in the cover.
