Help! Van drivtrain in dodge monaco?
Old 06-20-2019, 03:18 AM
superboonan's Avatar
Question Help! Van drivtrain in dodge monaco?
Hi!
Im new here and I am also a new first time mopar owner of a 1976 Dodge Monaco
the car is without drivetrain(engine tranny & propshaft) and right now Im trying to get it running as cheaply as possible and later put the proper bigblock in it.
I found a working cheap Dodge ram van 250b from 1988 or 99 with a 318 engine close to me.so does anybody now if i can swap the complete drivetrain and maybe only modify the mounts and shorten the propshaft
I havent found any info about it. some say that the transmission is way to big to fit and some say it does fit.
Old 06-20-2019, 04:43 AM
Welcome.
What engine is in the ‘88. Sounds very doable, the older unit will be easier without computer and electronics.
superboonan (06-20-2019)
Old 06-20-2019, 05:23 AM
If your going to do a big block later... Mite want to find a complete engine and trans used to install. Then you will have ost of the parts you need later.
But yes, you can fit a small block combo also in that car. What most of them are saying is that engine mounting and a 904 trans is what it will mostly take to get in set up in the chassis...
Good Luck... Welcome to the site.... Keep us posted on the build..
Old 06-20-2019, 06:08 AM
Thank you for answering! But you think the transmission from a van will physically fit the Monaco? Someone said that it's too big since it most probably have overdrive
Old 06-20-2019, 08:04 AM
Everything should work just fine, mounts should not be a problem because most Bbodys came with the 318 that year. The radiator will work because Chrysler used the same for big and small blocks. If the van has a 727 trans you will not need to shorten the drive shaft but it could have a 999.
Good luck with your project.
Old 06-20-2019, 08:06 AM
One more thing, welcome to the forum. 🙂
Old 06-20-2019, 08:53 AM
Thanks alot! But the Monaco is a C-body isn't it? Or did you refer to that vans are b bodys
Old 06-20-2019, 10:11 AM
The Royal Monaco is the Cbody Monaco is a Bbody.
Either one came with a 400 /727 or 318 /904 so if you van has a 727 trans that would be a big help but if it has the 999 a drive shaft for a904 will work.
Old 06-20-2019, 11:59 AM
Ok my bad it's a royal. Thank you so much for making it clear for me
Old 06-20-2019, 01:00 PM
The newer overdrive trans may take some modification to the tunnel behind the trans crossmember, could be hammer time.
Mt_Green
08-29-2016 05:55 PM
rommiesebo
08-22-2016 05:34 AM
Vantasia
07-06-2015 03:07 PM
62Furious
01-06-2014 05:03 AM
Sllack
08-17-2013 04:25 AM
Quick Reply: Help! Van drivtrain in dodge monaco?
