Vacuum Leak
Old 02-14-2009, 12:03 PM
340CUDA's Avatar
Vacuum Leak
As some of yall may know ive got a vacuum leak, I was wondering if anyone knows anything about the hose kits on hiperformancestore.com?
There kits apparently replace all under hood vacuum lines, a few coolant lines, the line from the windshield washer pump, and the vacuum line to the heating and A/C controller.
Old 02-14-2009, 02:34 PM
Are you sure that the vacuum leak is coming from a hose? It could be the intake or carb gasket.
If any of your hoses are cracked though, they could be sucking air in through those cracks.
Old 02-14-2009, 02:43 PM
340CUDA's Avatar
most of the hoses are dry-rotted, so i was gonna replace em anyway
the carb gasket needs replacing
and i think ive got a bad head gasket because whenever i put the pedal down and park it after there is oil all on the left valve cover and alternator
Old 02-14-2009, 03:02 PM
Is your breather filter on your left valve cover? I've seen oil come out of them before.
If your hoses are cracked, then it is a good idea to replace them all. Along with that carb gasket.
Old 02-14-2009, 10:45 PM
340CUDA's Avatar
yeah my breather hose is on the left, and it leaks really bad
im gonna order the kit sometime next week, and get a nex carb gasket
Old 02-15-2009, 06:19 AM
Your going to have to figure out why you have oil coming out of your breather. You shouldn't have that at all. Even if you fix all your hoses and replace those gaskets, you could still have ol coming out.
Old 02-15-2009, 10:51 AM
340CUDA's Avatar
i'll take a picture of the leak one day, put it up here and see what you think. originally i thought it was the valve covers but i guess not
Old 02-19-2009, 11:18 AM
challenger's Avatar
are you running headers on the motor and if so can you tell if the oil is coming from the header gaskets ???? ( between the head and the header)
Old 02-19-2009, 12:15 PM
ive never had oil come out from the header gasket
is that possible?
you would have to have bad seals on the springs wouldnt you?
Old 02-20-2009, 08:01 PM
340CUDA's Avatar
Sorry i meant cylinder head, the leak is on the left side and oil get all over the back of the alternator, bottom of the air filter and the valve cover
Old 02-21-2009, 08:27 AM
have to tried a compression test?
that might tell you if the head gasket is good
Old 02-21-2009, 11:14 AM
340CUDA's Avatar
I'll try that sometime this week
Old 02-21-2009, 11:18 AM
340CUDA's Avatar
how many lbs should i be looking for?
and how much difference between the cylinders before i need to worry?
Old 02-21-2009, 01:12 PM
if compression in 10 to 1, i think pressure is around 150? not sure though
10lb difference between cylinders is ok
Old 02-22-2009, 03:40 PM
340CUDA's Avatar
sorry i think i miss led you, the breather isnt leaking, somewhere on the left side of the engine its leaking...the breather was moved back a couple of inches when i changed the valve covers and the hose is kinked up a little bit
Old 02-22-2009, 03:55 PM
did you try a compression test?
Old 03-14-2009, 07:46 PM
340CUDA's Avatar
hey yall, orry it took so long to reply...we put the smoke machine on the engine and couldnt find any leaks, messed with the timing (it was way off) and that seemed to do the trick but it still sputters a little every now and then, and i still havent done a compression test will soon though
does anyone know where i can get a breather cap with a pcv valve in it?
Old 03-15-2009, 08:06 AM
i got mine off ebay
Old 03-15-2009, 03:59 PM
340CUDA's Avatar
alright, thanks GTX
Old 03-15-2009, 04:23 PM
challenger's Avatar
hey 67 when i changed oils to full synthetic i had a really bad problem if you remember as this some what started the zinc thingy on here but the FS oil was just flowing out my valve seals and was told by valvoline to change back to the VR1 oils as the FS oils have way to many cleaners in it and the VR1 has the right amount of additives in it to make it work for my engine and by the way it was like a faucet turned on with the oil pooring out my headers but the VR1 stoped all that
Old 03-16-2009, 05:27 PM
haha
i havent had any of those problems
hmm, now im wondering
josehf34
36
12-16-2014 06:05 AM
Robert Weaver
11-21-2014 08:11 PM
66coronetgirlie
08-09-2010 10:41 PM
Commando
09-23-2008 07:35 AM
burnsy26
10-01-2007 01:35 PM
Quick Reply: Vacuum Leak
