Dual exhaust
Old 05-18-2016, 05:17 PM
haines's Avatar
Dual exhaust
I have an 80 Volare with the gas tank offset. how do I put in dual exhaust as I have dropped the 225 and dropped in a 318?
Thanks,
Old 05-18-2016, 05:38 PM
I think you can only turn those out in front of the rear tire on each side...
Just my 2 cents....
Old 05-20-2016, 04:52 PM
haines's Avatar
Thanks, as it is not had the safety done it and I live in Canada they will not allow that.
Old 05-20-2016, 07:04 PM
How about stopping at the rear axle? Sorry Im not familiar with the inspection laws in the great white north...
Old 05-21-2016, 03:47 AM
I've seen over and under (shot gun style ) done, but I did an aspen once over the axel exiting behind the rear wheels.
Old 05-21-2016, 06:32 AM
Archer's Avatar
h -
I can't see the set up, so can't recommend anything specific, but are side pipes legal up north? Might look really cool.
Old 05-23-2016, 04:03 PM
Had a 77 Volare RR did the repo TA mufflers. DON'T drive next to a wall with the window open for any length of time
Old 09-02-2019, 10:28 AM
mraspen's Avatar
Re: exhaust
for late 77-80 aspens you can run duals out back like i did. you have to shift the gas tank over one set of ribs(bottom of the tank is ribbed) to the pass side. you will need to extend your filler neck by 1-2 inches. then the pass side is stock aspen v8 bends, drivers side is 69 dart 340 drivers side bends. if you know a good exhaust shop he will be able to find out where to bend specs are(thats how my shop did it,) this will give you true over the rear axle to under the bumper rear exit dual exhaust. unfortunately fo 76- mid 77 f bodies you cant do this with the hump tanks.
Hope this helps
Fred
Old 09-03-2019, 01:15 PM
nice advice, mraspen!
Old 09-03-2019, 03:58 PM
I'd recommend having the exhaust dump at the rear of the back tires if you have something more than mild street cruiser.
Old 09-07-2019, 09:19 AM
mraspen's Avatar
pics are posted in the gallery
Tucker Bear
03-28-2019 09:09 PM
QuaZi ET Gremlin
08-15-2013 03:33 PM
trivium
06-24-2011 07:30 AM
Ramahan
08-13-2010 01:14 PM
rocketken
09-16-2009 01:19 PM
Quick Reply: Dual exhaust
