85 D150 A/C question
Junior Member
on
I am trying to get the a/c compressor to come on but i get nothing. How can i tell is the clutch is bad or even getting a signal to come on. All the fuses are good what should i check next.
I think you can "hot wire" it with a jumper wire. If it kicks on, you will see the center of the pulley start to spin with the outer part. If this happens, your clutch is maybe OK.
thick10
02-17-2011 07:11 AM
