94 dodge ram 1500 5.9 4x4 stalls when put in gear
Old 02-27-2012, 03:48 PM
chuckorr's Avatar
Unhappy 94 dodge ram 1500 5.9 4x4 stalls when put in gear
I HAVE A 94 DODGE 1500 5.9 4X4 THAT STALLS WHEN I PUT IT IN DRIVE OR REVERSE. I CAN START IT UP AND IT IDLES FINE BUT WHEN I PUT IT INTO DRIVE OR REVERSE IT DIES. IT HAS NEW CAP & ROTOR, WIRES, PLUGS, CLUTCH SOLENOID, I'VE CLEANED THE IAC AND THE PORT IN THE TB, TESTED THE MAP SENSOR (IT'S WORKING), CHECKED FOR VACCUM LEAKS. IM STARTING TO GET WITH THIS THING! I'VE OWNED 2 OTHER DODGES, A 95 1500 5.9 2WD AND A 2002 1500 4.7 2WD AND HAVE NEVER HAD ANY PROBLEMS WITH THEM. PLEASE!!!!! I NEED HELP WITH THIS ONE!!!
Old 02-27-2012, 03:59 PM
Have you checked fuel pressure and regulator operation?
Old 02-27-2012, 04:02 PM
chuckorr's Avatar
NO NOT YET, I CANT SEEM TO GET IT TO IDLE RIGHT NOW. ITS TAKEN A TURN FOR THE WORSE
Old 02-27-2012, 06:17 PM
PK1
PK1's Avatar
did you swap 5 and 7 wires on the cap install?
Does rotor tip touch cap center? Cap seated correctly?
What is the vacuum at idle?
did you loosen or rotate the distributer? More that 1/4 inch will put the fire cycle of the injectors off.
lastly check primary and secondary voltage of coil. The coils are poorly designed and if it did idle and now wont, and wont fire look there first.
Old 02-28-2012, 02:25 AM
You have to be careful when cleaning the IAC and port. I've seen guys in the dealer get a perfectly running vehicle in, perform a tune-up, clean the IAC and then get a check engine light.
Old 02-28-2012, 11:26 AM
78doubleR's Avatar
Its prob the IAC or TPS.
Old 02-06-2014, 09:51 PM
LaurenMagnum360's Avatar
i have a similar problem, but only with reverse and after it has sat for a good 10 + minutes. On mine, i'm having fluid drain out of the torque converter, so if i start it, i need to put it in neutral for 10 seconds before shifting into gear. This is because our transmissions do not cycle fluid in park.
Old 02-07-2014, 01:19 AM
Can you get the truck to move working the gas ??? Could be a bad trans converter
Old 02-07-2014, 04:20 AM
Mr.4spd's Avatar
Clutch switch? So the truck is stick shifted? Try 5th gear, does it stall? Sounds like a dragging clutch to me, or the aic.
mopmop
07-29-2012 10:12 AM
northcoasttip
09-29-2011 03:00 PM
66_fury_III
03-13-2011 06:34 PM
crwchf16
10-11-2009 12:47 AM
plymouthrr1985
05-25-2009 05:22 PM
Quick Reply: 94 dodge ram 1500 5.9 4x4 stalls when put in gear
