440 + 671 blower
Old 06-18-2010, 11:36 AM
1974Roadrunner's Avatar
Lightbulb 440 + 671 blower
I recently bought a 78 440 out of a truck. It is going in my 74 RR that I have never got to drive
A friend of mine gave me a brand new 671 blower. I still have to buy all the attachments to mount this beast to my engine. Does anyone have any build ideas or experience? I am trying to build a street able monster on pump gas.
So far I plan on electric fan and I want to find an electric water pump and housing (to save some weight) but no luck yet. I would also like a nice roller cam. I plan on upgrading most internals.
Old 06-18-2010, 01:35 PM
A.K.A Bob Dodge
1966sportfury's Avatar
The extent of the engine preparation will depend entirely on how the engine is to be used. A supercharger can be installed on a stock engine with cast pistons and a cast crank as long as moderate boost (below 8 lbs.) is maintained and any detonation is strictly controlled. Engine speed should also be limited to 5,000 rpm. Detonation on cast pistons can easily break ring lands. Too much boost and/or detonation on a stock or worn engine can cause piston damage or burned valves. Most late model "smog" engines work well with a supercharger due to their lower compression ratios and smaller cam profiles
Old 06-18-2010, 01:43 PM
you need to build the motor around the 671
you can't just put it on
Old 06-18-2010, 01:47 PM
A.K.A Bob Dodge
why?
Old 06-18-2010, 10:55 PM
A.K.A Bob Dodge
a blower,super charger, turbo all they are is just a air pump.(an engine is a air pump) no need to change things unless you want high levels of boost, factory is fine for the street,
Old 06-19-2010, 07:39 AM
this is what I was referring to
i wasn't sure what the compression was on his motor
I saw 78 block, but just didn't want to assume low compression
you are right, low boost will be ok
ripping on me a little, huh?
Old 06-19-2010, 10:11 AM
A.K.A Bob Dodge
damn it someones got too!
Old 06-19-2010, 02:15 PM
haha
Old 07-01-2010, 09:44 AM
Junior Member
YellowDodge67's Avatar
im looking into doing something like this too, does anything special have to be done to the ignition system, and does a "blower" cam have to be run or just a regular cam?
Old 07-01-2010, 11:43 AM
A.K.A Bob Dodge
you can run a stock cam, depends on what you want, stock will work fine tho
Old 07-01-2010, 12:13 PM
I know I have to build the motor around using the 671. I was asking for inputs on how to build the motor around it. What kind of cam and head combo would have best bang for the buck. Would stroking it or leaving it a 440 be best? And what size carbs? Dual 750?
Or would I be better off selling it and just buying a good set of heads and cam?
Old 07-02-2010, 08:44 PM
HEMI-ITIS's Avatar
If you are starting with a stock block and rotating assembly,you need to figure out two thing first,what is your budget,,,,,,,,,,,and how much HP do you want to make???Also keep in mind what the rest of the drivtrain can handle
Old 07-10-2010, 02:52 AM
Kalaek's Avatar
Hey guys,
I'm actually thinking of building a 440 with a hampton blower also. Does anyone know what company makes a rotating assembly for low compression?
thanks
Old 11-21-2011, 08:21 PM
mongo330's Avatar
blower motor
i ran a blower car for six years the two most important things are compression should be 8 or under with 7lbs of boost and stainless steel valves the blower creates a ton of heat stock weak valves will not hold up trust me
Old 11-21-2011, 08:24 PM
mongo330's Avatar
blower pistons
[i recomend fordged dished blower pistons try SRP or arias
Old 11-21-2011, 08:26 PM
mongo330's Avatar
blower cam
[blowers usually run under 226 duration
Old 11-21-2011, 10:51 PM
Takes a lot of horsepower to turn that blower
raceware
15
05-05-2014 06:08 AM
jagarcia89
11-26-2013 07:59 AM
woody02
04-14-2012 09:58 AM
vinman
07-24-2010 08:26 PM
Achan
07-17-2009 07:34 PM
Quick Reply: 440 + 671 blower
