Another video of my Road Runner
Old 10-16-2013, 09:08 PM
98 SNAKE EATER's Avatar
Old 10-17-2013, 06:09 AM
pro-tech's Avatar
Great video...What causes the 2nd to 3rd rev between shifts?? My car does the same thing and I havent had time to investigate the cause...Bill
Old 10-17-2013, 07:34 AM
Thanks
I spoke with Torqueflite Patty and he said the 2-3 flare can be a result of a specific combination of release springs in the front clutch and/or release springs in the KD servo and that it's not necessarily bad if it's not excessive.
Mine flares consistently about ~300 RPM's and the last two times I dropped the pan, there were no shavings, so I'm just gunna leave it be.
Old 10-17-2013, 11:42 AM
Love hearing that engine purr. I bet that's one helluva ride.
Old 10-17-2013, 01:34 PM
pro-tech's Avatar
I was told it was the kick down band adjustment was to loose. It doesnt much matter now I took 2nd gear out playing a month or so ago.. As soon as I feel a little better Ill pull it and rebuild it to handle the HP and put a stall converter with it...Winter project along with a ton of other stuff...Bill
Old 10-17-2013, 07:17 PM
inri's Avatar
How many GoPros do you have? Like 4?!! Cool vid.
Old 10-17-2013, 07:18 PM
5, but one filled up the card about half way (I cut about 40 minutes of driving footage)
Old 10-18-2013, 05:41 PM
Love it.
Old 10-18-2013, 08:59 PM
Silverick's Avatar
Thanks for the ride!! That was fun!!
Old 11-05-2013, 10:06 PM
Moparbob's Avatar
Flare 1st to 2nd.... is the 2nd gear band adjustment too loose, so slow to apply and engage 2nd.(Front Band)
2nd to 3rd Flare is the same band, same problem, because the same fluid that applies the 3rd clutchs is also the same fluid to release 2nd band, which, if too loose disengages too quickly... allowing the flare until 3rd clutch grabs.
The 2nd "Front" Band is externally adjusted on the side of the 727 trans, so easy fix.
Northerndave
06-20-2013 12:15 PM
69RoadRunner383
02-21-2008 10:50 AM
runninbird
01-20-2008 10:42 AM
runninbird
01-12-2008 12:50 PM
runninbird
12-05-2007 01:22 PM
Quick Reply: Another video of my Road Runner
