1976 Dodge Aspen with a severe hesitation problem
Old 07-15-2014, 12:46 PM
Jeff1515's Avatar
Angry 1976 Dodge Aspen with a severe hesitation problem
My Dodge has 313,000 miles, but the motor is good. The problem is severe hesitation most noticeable when the car is warmed up. Hesitation happens when pulling away from a stop and while on the highway, making it difficult to get speed. It happens all the time. Does not spit up through the carb.
New plugs, wires, electronic module, EGR valve, distributor cap and rotor, coil, had the carburetor rebuilt, tried a new rebuilt, and now a third carb off a wreck. Timing is on the mark @ 2 degrees BTDC, but I noticed a little bounce back and forth between the timing mark andthe pulley notch when shining the light. Checked emissions system (ES) for vacuum leaks. Also tested ES by blocking off EGR valve from manifold and plugging the line. Then together did the same with the Vacuum Amplifier by plugging all the lines to the carb and manifold. No improvement. Vacuum Switch working, closed when cold and open with vacuum when hot.
This car is driving me nuts. I welcome all suggestions. Thank you.
Old 07-15-2014, 01:36 PM
pro-tech's Avatar
You need more timing 12*-16* BTDC whether it is a 6 or a V8. Esp. with the ethanol fuel.. Bill
Old 07-15-2014, 01:50 PM
Put a new timing chain and gear set in it.....
Just my 2 cents
Old 07-15-2014, 03:03 PM
Has it had a new timing chain installed recently ? It sounds like the timing is off. There are some mis marked gear sets out there Back in 77 even before ethanol I use to run 10 degrees before in my Volare .. You have some type of vacuum leak
chlngr1970
12-09-2013 05:49 PM
garthed
09-05-2013 05:58 PM
bremereric
03-18-2012 08:56 AM
bremereric
08-07-2011 08:57 AM
seck ap
11-02-2008 11:35 PM
Quick Reply: 1976 Dodge Aspen with a severe hesitation problem
