2012 NHRA Summit Southern Nats. Atlanta
Old 05-04-2012, 02:20 PM
Fri, 04 May 2012, 16:38 PM
Pro Stock Qualifying Notes, Session #1
By Rick Green
COMMERCE, Ga. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 32nd annual Summit Racing Equipment NHRA Southern Nationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Right Lane: Buddy Perkinson Runs 6.805/206.16, Now #1
Weather conditions: air temperature 85 degrees, relative humidity 51 percent, barometer 29.26 inches, adjusted altitude 3,303 feet, track temperature 124 degrees.
Perkinson making his first pass of the year...he spun right at the hit, but drove it on through the quarter-mile.
Left Lane: John Gaydosh Jr No Time, Now #3
Right Lane: Warren Johnson Runs 6.696/206.83, Now #1
Gaydosh Jr. broke after the burnout and was pushed off the starting line. Johnson was straight down the groove.
Left Lane: Grace Howell Runs 6.720/205.41, Now #3
Right Lane: V. Gaines Runs 6.668/208.14, Now #1
Gaines was straight down his groove, Howell goes to the number three spot for now.
Left Lane: Chris McGaha Runs 6.719/207.37, Now #3
Right Lane: Steve Kent Runs 7.387/140.36, Now #6
Kent with problems early and pushed in the clutch. McGaha goes to the number three spot.
Left Lane: Kurt Johnson Runs 6.664/207.40, Now #2
Right Lane: Ron Krisher Runs 6.649/208.52, Now #1
Johnson with the quickest 60-foot time of the round and he goes to the number two spot. Kurt Johnson's incremental times: 60ft-0.988 sec., 330ft-2.786, 660ft-4.284/164.73 mph, 1,000ft-5.575. Krisher with a real nice pass to the number one spot.
Left Lane: Jeg Coughlin Runs 6.687/207.85, Now #5
Right Lane: Shane Gray Runs 6.655/207.18, Now #2
Gray with a real nice pass to go to the number two spot. Shane Gray's incremental times: 60ft-0.991 sec., 330ft-2.783, 660ft-4.278/165.42 mph, 1,000ft-5.568. Coughlin goes to the number five spot.
Left Lane: Larry Morgan Runs 6.685/206.86, Now #6
Right Lane: Rodger Brogdon Runs 6.656/207.88, Now #3
Morgan goes to the number six spot...Larry Morgan's incremental times: 60ft-1.005 sec., 330ft-2.804, 660ft-4.303/164.63 mph, 1,000ft-5.594. Brogdon goes to the number three spot. Rodger Brogdon's incremental times: 60ft-1.007 sec., 330ft-2.801, 660ft-4.289/166.17 mph, 1,000ft-5.573.
Left Lane: Greg Stanfield Runs 6.700/206.04, Now #10
Right Lane: Ronnie Humphrey Runs 6.653/207.88, Now #2
Humphrey goes to the number two spot...Ronnie Humphrey's incremental times: 60ft-1.003 sec., 330ft-2.793, 660ft-4.283/165.99 mph, 1,000ft-5.569. Stanfield gets in the show for now. Greg Stanfield's incremental times: 60ft-1.000 sec., 330ft-2.802, 660ft-4.308/163.67 mph, 1,000ft-5.605.
Left Lane: Erica Enders Runs 6.661/207.11, Now #6
Right Lane: Allen Johnson Runs 6.620/209.07, Now #1
Johnson with a great pass to go to the number one spot with a great pass. Allen Johnson's incremental times: 60ft-1.000 sec., 330ft-2.781, 660ft-4.264/166.89 mph, 1,000ft-5.542. Enders gets into the top half of the show...Erica Enders' incremental times: 60ft-0.995 sec., 330ft-2.786, 660ft-4.282/164.69 mph, 1,000ft-5.572.
Left Lane: Mike Edwards Runs 6.638/208.71, Now #2
Right Lane: Vincent Nobile Runs 6.654/208.26, Now #5
Edwards goes to the number two spot...Mike Edwards' incremental times: 60ft-0.995 sec., 330ft-2.782, 660ft-4.273/165.50 mph, 1,000ft-5.556. Nobile gets in the top half of the show. Vincent Nobile's incremental times: 60ft-1.002 sec., 330ft-2.796, 660ft-4.288/166.19 mph, 1,000ft-5.572.
Left Lane: Jason Line Runs 6.680/199.67, Now #12
Right Lane: Greg Anderson Runs 6.647/208.17, Now #3
Line with the quickest 60-foot time of the round, but then slows. He gets in the show on the bubble. Jason Line's incremental times: 60ft-0.989 sec., 330ft-2.779, 660ft-4.279/164.29 mph, 1,000ft-5.575. Anderson goes to the number three spot...Greg Anderson's incremental times: 60ft-1.003 sec., 330ft-2.792, 660ft-4.280/166.23 mph, 1,000ft-5.564.
Timing data courtesy of CompuLink
Old 05-05-2012, 03:41 AM
Qualifying Round 2
Fri, 04 May 2012, 18:58 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
COMMERCE, Ga. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 32nd annual Summit Racing Equipment NHRA Southern Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Steve Kent Runs 6.656/207.53, Now #9; Best prior run: 7.387/140.36, Was #20
Weather conditions: air temperature 85 degrees, relative humidity 51 percent, barometer 29.24 inches, adjusted altitude 3,336 feet, track temperature 120 degrees.
Kent with a good pass to get in the show...Steve Kent's incremental times: 60ft-1.001 sec., 330ft-2.786, 660ft-4.278/164.85 mph, 1,000ft-5.568.
Left Lane: Buddy Perkinson Runs 6.709/206.86, Now #18; Best prior run: 6.805/206.16, Was #20
Right Lane: John Gaydosh Jr No Time, Now #21; No Prior Run
Gaydosh Jr. used up an engine and was trailing smoke all the way down the track. Apparently he got out of the groove and crossed the centerline. Perkinson made a move in the right direction, but not enough to get in the show.
Left Lane: Warren Johnson Runs 6.699/206.20, Now #16; Best prior run: 6.696/206.83, Was #16
Right Lane: Grace Howell No Time, Now #20; Best prior run: 6.720/205.41, Was #20
Howell was leaking something after the burnout and was shut off. No help here for Johnson and he will start over tomorrow.
Left Lane: V. Gaines Runs 9.897/83.19, Now #13; Best prior run: 6.668/208.14, Was #12
Right Lane: Chris McGaha Runs 6.657/207.91, Now #10; Best prior run: 6.719/207.37, Was #19
Gaines is out of the groove early and got real close to the wall before he clicked it off. McGaha with a real nice pass, straight down the groove to get in the show. That will bump out Gaines and put Kurt Johnson on the bump spot at 6.664.
Left Lane: Rodger Brogdon Runs 6.643/207.56, Now #3; Best prior run: 6.656/207.88, Was #8
Right Lane: Greg Stanfield Runs 6.696/206.04, Now #18; Best prior run: 6.700/206.04, Was #18
Stanfield is slight better than his earlier run from today and he will not get in the show. Brogdon with a great pass to go to the number three spot. Rodger Brogdon's incremental times: 60ft-0.996 sec., 330ft-2.781, 660ft-4.271/165.44 mph, 1,000ft-5.557.
Left Lane: Shane Gray Runs 6.662/207.27, Now #8; Best prior run: 6.655/207.18, Was #8
Right Lane: Jeg Coughlin Runs 6.677/207.66, Now #14; Best prior run: 6.687/207.85, Was #16
No help here for Gray, but another good pass. Shane Gray's incremental times: 60ft-0.997 sec., 330ft-2.785, 660ft-4.282/164.69 mph, 1,000ft-5.574. Coughlin improves, but not enough to get in the show. Jeg Coughlin's incremental times: 60ft-1.011 sec., 330ft-2.806, 660ft-4.301/165.50 mph, 1,000ft-5.591.
Left Lane: Vincent Nobile Runs 6.649/208.52, Now #6; Best prior run: 6.654/208.26, Was #7
Right Lane: Larry Morgan Runs 6.654/207.37, Now #8; Best prior run: 6.685/206.86, Was #16
Nobile moves up the ladder one spot with a real nice pass. Vincent Nobile's incremental times: 60ft-1.005 sec., 330ft-2.792, 660ft-4.283/165.56 mph, 1,000ft-5.567. Morgan with a big move in the right direction to get in the show. Larry Morgan's incremental times: 60ft-0.994 sec., 330ft-2.785, 660ft-4.279/165.38 mph, 1,000ft-5.567.
Left Lane: Ronnie Humphrey Runs 6.631/208.88, Now #3; Best prior run: 6.653/207.88, Was #7
Right Lane: Jason Line Runs 6.612/208.68, Now #1; Best prior run: 6.680/199.67, Was #16
Apparently Line used up an engine in round one, and he has a great pass here to go to the number one spot. Jason Line's incremental times: 60ft-0.988 sec., 330ft-2.767, 660ft-4.252/166.66 mph, 1,000ft-5.532. Humphrey with a real nice pass to move into the top half of the show. Ronnie Humphrey's incremental times: 60ft-1.006 sec., 330ft-2.787, 660ft-4.272/165.94 mph, 1,000ft-5.552.
Left Lane: Ron Krisher Runs 6.637/208.91, Now #4; Best prior run: 6.649/208.52, Was #7
Right Lane: Kurt Johnson Runs 6.688/207.56, Now #14; Best prior run: 6.664/207.40, Was #14
No help here for Johnson and he will start over tomorrow. Krisher with a real nice pass to get into the top half of the show. Ron Krisher's incremental times: 60ft-0.992 sec., 330ft-2.783, 660ft-4.273/165.38 mph, 1,000ft-5.557.
Left Lane: Greg Anderson Runs 6.625/208.62, Now #3; Best prior run: 6.647/208.17, Was #7
Right Lane: Erica Enders Runs 6.644/207.69, Now #8; Best prior run: 6.661/207.11, Was #13
Anderson with a good short time and goes to the number three spot. Greg Anderson's incremental times: 60ft-0.992 sec., 330ft-2.773, 660ft-4.260/165.60 mph, 1,000ft-5.543. Enders makes a move in the right direction to get in the show and that bumps out McGaha. Steve Kent is on the bump spot at 6.656.
Left Lane: Allen Johnson Runs 6.613/209.23, Now #2; Best prior run: 6.620/209.07, Was #2
Right Lane: Mike Edwards Runs 6.635/208.59, Now #5; Best prior run: 6.638/208.71, Was #6
Edwards with a real good pass and moves up the ladder one spot. Mike Edwards' incremental times: 60ft-0.991 sec., 330ft-2.779, 660ft-4.269/166.17 mph, 1,000ft-5.553. Johnson launched hard and keep it hooked up to go to the number two spot. Allen Johnson's incremental times: 60ft-0.994 sec., 330ft-2.772, 660ft-4.256/166.13 mph, 1,000ft-5.535.
From Dragracecentral.com
Old 05-05-2012, 09:27 AM
Round 3 Qualifying
Sat, 05 May 2012, 12:19 PM
Pro Stock Qualifying Notes, Session #3
By Rick Green
COMMERCE, Ga. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 32nd annual Summit Racing Equipment NHRA Southern Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Right Lane: V. Gaines Runs 7.145/205.16, Now #13; No Prior Run
Weather conditions: air temperature 86 degrees, relative humidity 54 percent, barometer 29.24 inches, adjusted altitude 3,425 feet, track temperature 102 degrees.
Gaines spun the tires hard and then drove it on through to get a number on the board.
Left Lane: Grace Howell Runs 6.724/205.38, Now #14; No Prior Run
Right Lane: Buddy Perkinson Runs 6.716/206.99, Now #13; No Prior Run
They both get numbers on the boards, slower than yesterday. Grace Howell's incremental times: 60ft-1.011 sec., 330ft-2.816, 660ft-4.321/163.33 mph, 1,000ft-5.625.
Buddy Perkinson's incremental times: 60ft-1.012 sec., 330ft-2.828, 660ft-4.331/164.81 mph, 1,000ft-5.626.
Left Lane: John Gaydosh Jr Runs 6.937/200.02, Now #16; No Prior Run
Right Lane: Warren Johnson Runs 6.710/206.35, Now #13; No Prior Run
Gaydosh is real loose right at the hit, but reels it in and gets in the show on the bump spot. John Gaydosh Jr's incremental times: 60ft-1.023 sec., 330ft-2.907, 660ft-4.468/158.07 mph, 1,000ft-5.808. WJ gets in the show for now. Warren Johnson's incremental times: 60ft-1.013 sec., 330ft-2.815, 660ft-4.318/164.35 mph, 1,000ft-5.616.
Left Lane: Greg Stanfield Runs 6.697/206.23, Now #13; No Prior Run
Right Lane: Shane Gray Runs 6.643/206.99, Now #8; Best prior run: 6.655/207.18, Was #11
Gray with the quickest pass of the session and he gets into the top half of the show. Shane Gray's incremental times: 60ft-0.982 sec., 330ft-2.767, 660ft-4.263/165.44 mph, 1,000ft-5.554. Stanfield with the second quickest pass of the session and that gets him into the show... Greg Stanfield's incremental times: 60ft-1.001 sec., 330ft-2.796, 660ft-4.302/163.67 mph, 1,000ft-5.601.
Left Lane: Kurt Johnson Runs 6.674/207.72, Now #13; No Prior Run
Right Lane: Steve Kent Runs 6.645/207.85, Now #10; Best prior run: 6.656/207.53, Was #12
Kent with the second quickest pass of the round to move up the ladder a couple spots. Steve Kent's incremental times: 60ft-1.002 sec., 330ft-2.784, 660ft-4.273/165.92 mph, 1,000ft-5.560. Johnson slows from his time yesterday, but gets in the show. Kurt Johnson's incremental times: 60ft-1.012 sec., 330ft-2.802, 660ft-4.298/164.93 mph, 1,000ft-5.587.
Left Lane: Jeg Coughlin Runs 6.699/207.05, Now #15; No Prior Run
Right Lane: Vincent Nobile Runs 6.638/208.49, Now #7; Best prior run: 6.649/208.52, Was #11
Nobile with the quickest pass of the round and he moves into the top half of the show. Vincent Nobile's incremental times: 60ft-1.002 sec., 330ft-2.786, 660ft-4.274/166.21 mph, ,000ft-5.557. Coughlin with a good pass to get in the show and that puts Warren Johnson on the bump spot at 6.710. Jeg Coughlin's incremental times: 60ft-1.019 sec., 330ft-2.816, 660ft-4.315/164.25 mph, 1,000ft-5.609.
Left Lane: Chris McGaha Runs 15.115/47.01, Now #21; No Prior Run
Right Lane: Rodger Brogdon Runs 6.649/207.98, Now #8; Best prior run: 6.643/207.56, Was #8
McGaha shook hard right off the starting line and pushed in the clutch. Brogdon almost matches his time from yesterday. Rodger Brogdon's incremental times: 60ft-1.000 sec., 330ft-2.790, 660ft-4.280/166.01 mph, 1,000ft-5.566.
Left Lane: Larry Morgan Runs 6.679/206.86, Now #12; Best prior run: 6.654/207.37, Was #12
Right Lane: Ron Krisher Runs 6.639/208.84, Now #6; Best prior run: 6.637/208.91, Was #6
Krisher with the quickest short time of the round and parlays that into the second quickest pass of the session. Ron Krisher's incremental times: 60ft-0.996 sec., 330ft-2.785, 660ft-4.275/165.99 mph, 1,000ft-5.559. Morgan with a good pass, but will stay in the number 12 spot. Larry Morgan's incremental times: 60ft-1.007 sec., 330ft-2.798, 660ft-4.296/164.21 mph, 1,000ft-5.589.
Left Lane: Erica Enders Runs 6.637/208.20, Now #7; Best prior run: 6.644/207.69, Was #10
Right Lane: Ronnie Humphrey Runs 6.632/208.20, Now #4; Best prior run: 6.631/208.88, Was #4
This was a great side-by-side drag race...Humphrey is just a tick off his qualifying time from yesterday. The quickest of the round. Ronnie Humphrey's incremental times: 60ft-0.992 sec., 330ft-2.779, 660ft-4.266/166.13 mph, 1,000ft-5.550. Enders matches her time from yesterday with a real nice pass, the second quickest pass of the round. Erica Enders' incremental times: 60ft-0.996 sec., 330ft-2.780, 660ft-4.270/165.36 mph, 1,000ft-5.554.
Left Lane: Mike Edwards Runs 11.459/69.10, Now #5; Best prior run: 6.635/208.59, Was #5
Right Lane: Greg Anderson Runs 6.629/208.84, Now #3; Best prior run: 6.625/208.62, Was #3
Edwards spun the tires hard right at the hit and clicked it off. Anderson with the second quickest 60-foot time of the round and then runs the quickest pass of the round. Greg Anderson's incremental times: 60ft-0.995 sec., 330ft-2.778, 660ft-4.264/166.42 mph, 1,000ft-5.547.
Left Lane: Jason Line Runs 6.607/209.04, Now #1; Best prior run: 6.612/208.68, Was #1
Right Lane: Allen Johnson Runs 6.618/208.97, Now #2; Best prior run: 6.613/209.23, Was #2
This was a great drag race to wrap up this session of qualifying. Line with the quickest pass 60-foot time of the round and he parlays that into the quickest pass of the weekend to hold on to the number one spot. Jason Line's incremental times: 60ft-0.986 sec., 330ft-2.764, 660ft-4.248/166.01 mph, 1,000ft-5.528. Johnson with a great pass, just a tick off his qualifying time from yesterday to hold on to the number two spot. Allen Johnson's incremental times: 60ft-0.994 sec., 330ft-2.779, 660ft-4.263/166.87 mph, 1,000ft-5.541.
From DragRaceCentral.com
Old 05-05-2012, 12:31 PM
Final Qualifying
Sat, 05 May 2012, 15:11 PM
Pro Stock Qualifying Notes, Final Session
By Rick Green
COMMERCE, Ga. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 32nd annual Summit Racing Equipment NHRA Southern Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: V. Gaines Runs 8.995/96.89, Now #20; Best prior run: 7.145/205.16, Was #20
Weather conditions: air temperature 88 degrees, relative humidity 45 percent, barometer 29.14 inches, adjusted altitude 3,595 feet, track temperature 133 degrees.
Gaines was out of the groove early and over by the wall before he clicked it off. Gaines will not qualify.
Left Lane: Buddy Perkinson Runs 6.727/206.92, Now #17; Best prior run: 6.716/206.99, Was #17
Right Lane: Chris McGaha Runs 15.019/49.05, Now #21; Best prior run: 15.115/47.01, Was #21
McGaha made a quick move toward the wall and clicked it off. Perkinson slows from his earlier time today and he will not get in the show.
Left Lane: Warren Johnson Runs 6.737/206.39, Now #16; Best prior run: 6.710/206.35, Was #16
Right Lane: John Gaydosh Jr Runs 13.606/63.92, Now #19; Best prior run: 6.937/200.02, Was #19
Gaydosh shook right off the starting line and clicked it off. No help here for WJ...
Left Lane: Steve Kent Runs 6.690/207.02, Now #11; Best prior run: 6.645/207.85, Was #11
Right Lane: Grace Howell Runs 6.729/205.26, Now #18; Best prior run: 6.724/205.38, Was #18
Howell slows from earlier today and she will not get in the show. Kent with the quickest pass of the round, but will stay in the number 11 spot.
Left Lane: Shane Gray Runs 6.676/207.08, Now #10; Best prior run: 6.643/206.99, Was #10
Right Lane: Jeg Coughlin Runs 6.695/207.62, Now #14; Best prior run: 6.699/207.05, Was #15
Coughlin improves on his time from earlier today and move up the ladder one spot. Jeg Coughlin's incremental times: 60ft-1.020 sec., 330ft-2.813, 660ft-4.312/164.97 mph, 1,000ft-5.606. No help here for Gray.
Left Lane: Rodger Brogdon Runs 6.678/207.40, Now #9; Best prior run: 6.643/207.56, Was #9
Right Lane: Greg Stanfield Runs 6.694/205.94, Now #14; Best prior run: 6.697/206.23, Was #15
Stanfield with the quickest 60-foot time of the round and the fourth quickest pass of the round. Greg Stanfield's incremental times: 60ft-0.989 sec., 330ft-2.787, 660ft-4.295/163.83 mph, 1,000ft-5.597. No help here for Brogdon, but still the second quickest pass of the round. Rodger Brogdon's incremental times: 60ft-1.001 sec., 330ft-2.795, 660ft-4.296/164.15 mph, 1,000ft-5.589.
Left Lane: Vincent Nobile Runs 6.664/208.26, Now #8; Best prior run: 6.638/208.49, Was #8
Right Lane: Kurt Johnson Runs 6.661/207.30, Now #13; Best prior run: 6.674/207.72, Was #13
This was good side-by-side drag race. Johnson with the quickest pass of the round...Kurt Johnson's incremental times: 60ft-0.996 sec., 330ft-2.787, 660ft-4.282/165.56 mph, 1,000ft-5.573. Nobile the second quickest of the session. Vincent Nobile's incremental times: 60ft-1.012 sec., 330ft-2.800, 660ft-4.293/165.23 mph, 1,000ft-5.580.
Left Lane: Ron Krisher Runs 6.664/207.94, Now #6; Best prior run: 6.637/208.91, Was #6
Right Lane: Larry Morgan Runs 6.686/207.02, Now #12; Best prior run: 6.654/207.37, Was #12
Krisher ties Nobile for the third quickest pass of the session, but runs faster. Ron Krisher's incremental times: 60ft-1.010 sec., 330ft-2.795, 660ft-4.290/164.51 mph, 1,000ft-5.578. Morgan with another good pass. Ron Krisher's incremental times: 60ft-1.010 sec., 330ft-2.795, 660ft-4.290/164.51 mph, 1,000ft-5.578.
Left Lane: Ronnie Humphrey Runs 6.679/207.27, Now #4; Best prior run: 6.631/208.88, Was #4
Right Lane: Erica Enders Runs 6.655/207.56, Now #7; Best prior run: 6.637/208.20, Was #7
Enders with the quickest pass of the round...Erica Enders' incremental times: 60ft-0.999 sec., 330ft-2.786, 660ft-4.280/165.50 mph, 1,000ft-5.569. Humphrey with another good pass.Ronnie Humphrey's incremental times: 60ft-1.004 sec., 330ft-2.802, 660ft-4.299/164.65 mph, 1,000ft-5.591.
Left Lane: Greg Anderson Runs 6.662/208.14, Now #3; Best prior run: 6.625/208.62, Was #3
Right Lane: Mike Edwards Runs 6.645/208.33, Now #5; Best prior run: 6.635/208.59, Was #5
Edwards with the quickest pass of the round and he will start from the number five spot. Mike Edwards' incremental times: 60ft-1.000 sec., 330ft-2.787, 660ft-4.279/165.94 mph, 1,000ft-5.563. Anderson with another good pass, fourth quickest of the round. Greg Anderson's incremental times: 60ft-1.003 sec., 330ft-2.794, 660ft-4.288/164.97 mph, 1,000ft-5.577.
Left Lane: Allen Johnson Runs 6.637/208.23, Now #2; Best prior run: 6.613/209.23, Was #2
Right Lane: Jason Line Runs 6.629/208.39, Now #1; Best prior run: 6.607/209.04, Was #1
This was a great way to wrap up qualifying with the two quickest cars of the event running the two quickest passes of the round. Line was quickest and Johnson was right there with him. Allen Johnson's incremental times: 60ft-1.000 sec., 330ft-2.783, 660ft-4.271/165.72 mph, 1,000ft-5.555.
Jason Line's incremental times: 60ft-0.994 sec., 330ft-2.776, 660ft-4.264/166.23 mph, 1,000ft-5.547.
Old 05-07-2012, 02:48 PM
Smmary of Eliminations
Sun, 06 May 2012, 17:11 PM
Summary of Eliminations in Pro Stock
COMMERCE, Ga. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 32nd annual Summit Racing Equipment NHRA Southern Nationals:
Round 1:
Vincent Nobile, Dix Hills NY, '12 Avenger, Right lane, (0.009) 6.633 208.91 def. Rodger Brogdon,Tomball TX, '09 GXP, (0.039) 6.646 209.01
Erica Enders, New Orleans LA, '10 Cobalt, Right lane, (0.020) 6.618 208.75 def. Shane Gray, DenverNC, '09 GXP, (0.037) 6.617 208.36
Mike Edwards, Coweta OK, '09 GXP, Right lane, (0.004) 6.631 208.75 def. Larry Morgan, Newark OH,'12 Mustang, (0.010) 6.668 208.04
Ronnie Humphrey, Jacksonville NC, '09 GXP, Right lane, (0.003) 6.649 208.97 def. Kurt Johnson,Sugar Hill GA, '09 GXP, (0.070) 6.639 208.55
Greg Anderson, Mooresville NC, '09 GXP, Right lane, (0.056) 6.624 209.49 def. Greg Stanfield,Bossier City LA, '12 Camaro, (0.040) 6.665 207.46
Allen Johnson, Greeneville TN, '12 Avenger, Right lane, (0.073) 6.594 209.98 def. Jeg Coughlin,Delaware OH, '12 Avenger, (0.032) 6.653 208.52
Jason Line, Troutman NC, '09 GXP, Right lane, (0.083) 6.599 209.95 def. Warren Johnson, Sugar HillsGA, '09 GXP, (0.080) 6.722 206.54
Steve Kent, Lottie LA, '09 GXP, Left lane, (0.119) 6.635 208.84 def. Ron Krisher, Warren OH, '09GXP, (0.172) 13.595 63.20
Round 2:
R Humphrey, Left lane, (0.027) 6.673 208.17 def. M Edwards, (0.067) 6.647 209.04
G Anderson, Right lane, (0.064) 6.623 209.23 def. S Kent, (-0.353 foul) 6.659 208.59
J Line, Right lane, (0.012) 6.605 209.49 def. V Nobile, (0.007) 6.646 209.14
A Johnson, Right lane, (0.038) 6.613 209.75 def. E Enders, (0.024) 6.637 208.46
Round 3:
G Anderson, Left lane, (0.063) 6.670 208.75 def. A Johnson, (0.011) 17.209 45.41
J Line, Right lane, (0.046) 6.634 209.26 def. R Humphrey, (0.078) 12.278 70.83
Round 4:
G Anderson, Left lane, (0.039) 6.649 208.26 def. J Line, (0.081) 6.618 209.62
Low ET: Allen Johnson 6.594 seconds
Top Speed: Allen Johnson 209.98 MPH
MReeves
Funny Car
05-07-2012 02:53 PM
MReeves
Stock Eliminator
05-06-2012 10:04 AM
MReeves
Super Stock
05-05-2012 02:46 PM
MReeves
Super Gas
05-05-2012 09:16 AM
MReeves
Stock Eliminator
05-15-2010 06:45 PM
Quick Reply: 2012 NHRA Summit Southern Nats. Atlanta
