NHRA Big O Tries Nationals Las Vegas
Old 10-28-2011, 01:36 PM
Fri, 28 Oct 2011, 04:12 PM
Pro Stock Qualifying Notes, Session #1
By Rick Green
LAS VEGAS - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 11th annual Big O Tires NHRA Nationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Left Lane: Mark Wolfe Runs 6.771/205.16, Now #2
Right Lane: Grace Howell Runs 6.758/204.82, Now #1
Weather conditions: air temperature 73 degrees, relative humidity 15 percent, barometer 28.03 inches, adjusted altitude 3,420 feet, track temperature 101 degrees.
Mark Wolfe's incremental times: 60ft-1.029 sec., 330ft-2.854, 660ft-4.366/162.74 mph, 1,000ft-5.671.
Grace Howell's incremental times: 60ft-1.028 sec., 330ft-2.844, 660ft-4.355/163.02 mph, 1,000ft-5.658.
Left Lane: Gordie Rivera Runs 6.823/202.09, Now #4
Right Lane: Buddy Perkinson Runs 6.736/204.32, Now #1
Perkinson has problems getting the car to start...still make a real nice pass.
Left Lane: Steve Kent Runs 6.697/206.07, Now #2
Right Lane: Warren Johnson Runs 6.693/206.76, Now #1
These two are side-by-sie all the way down the track. Steve Kent's incremental times: 60ft-1.001 sec., 330ft-2.803, 660ft-4.306/163.45 mph, 1,000ft-5.603.
Warren Johnson's incremental times: 60ft-1.000 sec., 330ft-2.802, 660ft-4.307/163.83 mph, 1,000ft-5.602.
Left Lane: V. Gaines Runs 6.716/206.35, Now #3
Right Lane: Larry Morgan Runs 6.769/203.68, Now #6
Morgan slowed on the top end...
Left Lane: Kurt Johnson Runs 6.686/206.61, Now #2
Right Lane: Ronnie Humphrey Runs 6.650/206.76, Now #1
Humphrey launched hard and was straight down the groove to go to the number one spot. Ronnie Humphrey's incremental times: 60ft-0.984 sec., 330ft-2.771, 660ft-4.267/164.37 mph, 1,000ft-5.559. Johnson goes to the number two spot. Kurt Johnson's incremental times: 60ft-0.998 sec., 330ft-2.795, 660ft-4.298/163.35 mph, 1,000ft-5.594.
Left Lane: Ron Krisher Runs 6.638/208.33, Now #1
Right Lane: Shane Gray Runs 6.688/206.35, Now #4
Krisher with a great pass, straight down the groove to go to the number one spot. He sets the the track speed record. Ron Krisher's incremental times: 60ft-0.993 sec., 330ft-2.782, 660ft-4.273/165.03 mph, 1,000ft-5.556. Gray with a great pass to start the weekend. Shane Gray's incremental times: 60ft-0.999 sec., 330ft-2.797, 660ft-4.298/164.11 mph, 1,000ft-5.594.
Left Lane: Greg Stanfield Runs 6.670/206.95, Now #3
Right Lane: Rodger Brogdon Runs 7.372/140.84, Now #14
Brogdon shook and pushed in the clutch...Stanfield with a real nice pass to go to the number three spot. Greg Stanfield's incremental times: 60ft-0.998 sec., 330ft-2.790, 660ft-4.288/164.37 mph, 1,000ft-5.580.
Left Lane: Allen Johnson Runs 6.654/208.07, Now #4
Right Lane: Mike Edwards Runs 6.627/208.33, Now #1
This was a great side-by-side drag race...Edwards goes to the number one spot and ties Krisher's track speed record. Mike Edwards' incremental times: 60ft-0.984 sec., 330ft-2.770, 660ft-4.260/165.31 mph, 1,000ft-5.544. Johnson had just a little wiggle on the top end. Allen Johnson's incremental times: 60ft-1.001 sec., 330ft-2.790, 660ft-4.282/164.61 mph, 1,000ft-5.569.
Left Lane: Erica Enders Runs 6.652/207.56, Now #4
Right Lane: Vincent Nobile Runs 6.655/207.50, Now #6
These two were side-by-side all the way down the track....Erica Enders' incremental times: 60ft-0.992 sec., 330ft-2.783, 660ft-4.278/164.53 mph, 1,000ft-5.566.
Vincent Nobile's incremental times: 60ft-0.989 sec., 330ft-2.780, 660ft-4.277/164.51 mph, 1,000ft-5.568.
Left Lane: Greg Anderson Runs 6.650/207.94, Now #4
Right Lane: Jason Line Runs 6.624/207.66, Now #1
Line launched hard and was just a tick off the track E.T. record to go to the number one spot. Jason Line's incremental times: 60ft-0.983 sec., 330ft-2.762, 660ft-4.252/165.19 mph, 1,000ft-5.538. Anderson with a nice pass to start the weekend...Greg Anderson's incremental times: 60ft-0.998 sec., 330ft-2.787, 660ft-4.279/164.67 mph, 1,000ft-5.566.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old 10-28-2011, 07:01 PM
Round 2 Qualifying
Fri, 28 Oct 2011, 07:48 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
LAS VEGAS - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 11th annual Big O Tires NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Rodger Brogdon Runs 6.683/207.18, Now #10; Best prior run: 7.372/140.84, Was #20
Right Lane: Gordie Rivera Runs 6.860/202.03, Now #20; Best prior run: 6.823/202.09, Was #19
Weather conditions: air temperature 80 degrees, relative humidity 17 percent, barometer 27.96 inches, adjusted altitude 3,979 feet, track temperature 102 degrees.
Brogdon with a nice pass to get in the show. Rodger Brogdon's incremental times: 60ft-1.005 sec., 330ft-2.803, 660ft-4.302/164.03 mph, 1,000ft-5.594. No help here for Rivera...
Left Lane: Larry Morgan Runs 6.677/206.86, Now #10; Best prior run: 6.769/203.68, Was #18
Right Lane: Mark Wolfe Runs 6.708/206.35, Now #16; Best prior run: 6.771/205.16, Was #19
Morgan launched hard and keep it hooked up to get in the show. Larry Morgan's incremental times: 60ft-1.001 sec., 330ft-2.797, 660ft-4.295/164.15 mph, 1,000ft-5.587. Wolfe improves, but not enough to get in the show. Mark Wolfe's incremental times: 60ft-1.014 sec., 330ft-2.817, 660ft-4.321/163.87 mph, 1,000ft-5.616.
Left Lane: Grace Howell Runs 6.754/203.89, Now #19; Best prior run: 6.758/204.82, Was #19
Right Lane: V. Gaines Runs 6.701/206.51, Now #16; Best prior run: 6.716/206.35, Was #17
Howell improves, but not enough to get in the show. Gaines will not get in the show, but improves.
Left Lane: Buddy Perkinson Runs 6.746/204.63, Now #18; Best prior run: 6.736/204.32, Was #18
Right Lane: Steve Kent Runs 6.687/206.07, Now #13; Best prior run: 6.697/206.07, Was #15
Kent just misses getting in the show. Steve Kent's incremental times: 60ft-0.993 sec., 330ft-2.790, 660ft-4.294/163.85 mph, 1,000ft-5.593. No help here for Perkinson.
Left Lane: Warren Johnson Runs 7.819/129.17, Now #15; Best prior run: 6.693/206.76, Was #15
Right Lane: Kurt Johnson Runs 6.683/206.32, Now #12; Best prior run: 6.686/206.61, Was #12
Kurt Johnson improves, but doesn't doesn't move off the bump. Warren shook and clicked it off.
Left Lane: Shane Gray Runs 6.698/206.26, Now #14; Best prior run: 6.688/206.35, Was #14
Right Lane: Greg Stanfield Runs 6.669/206.35, Now #9; Best prior run: 6.670/206.95, Was #9
Stanfield improves, but doesn't move up the ladder. Greg Stanfield's incremental times: 60ft-0.988 sec., 330ft-2.783, 660ft-4.284/164.27 mph, 1,000ft-5.577. Gray with another good pass...Shane Gray's incremental times: 60ft-1.002 sec., 330ft-2.802, 660ft-4.306/163.71 mph, 1,000ft-5.604.
Left Lane: Vincent Nobile Runs 6.678/207.30, Now #8; Best prior run: 6.655/207.50, Was #8
Right Lane: Allen Johnson Runs 6.656/207.62, Now #7; Best prior run: 6.654/208.07, Was #7
A couple good passes, but neither driver improves...Vincent Nobile's incremental times: 60ft-1.001 sec., 330ft-2.798, 660ft-4.298/164.11 mph, 1,000ft-5.589.
Allen Johnson's incremental times: 60ft-0.991 sec., 330ft-2.783, 660ft-4.279/164.49 mph, 1,000ft-5.569.
Left Lane: Ronnie Humphrey Runs 7.248/133.75, Now #5; Best prior run: 6.650/206.76, Was #5
Right Lane: Erica Enders Runs 6.653/207.18, Now #6; Best prior run: 6.652/207.56, Was #6
Humphrey's engine lets go with a lot of engine smoke, it filled the car with smoke. Enders with the quickest pass of the round, but will not move up the ladder. Erica Enders' incremental times: 60ft-0.988 sec., 330ft-2.778, 660ft-4.274/164.53 mph, 1,000ft-5.565.
Left Lane: Mike Edwards Runs 6.641/208.07, Now #2; Best prior run: 6.627/208.33, Was #2
Right Lane: Greg Anderson Runs 6.633/208.14, Now #3; Best prior run: 6.650/207.94, Was #4
Anderson with the quickest pass of the round and moves up the ladder one spot. Greg Anderson's incremental times: 60ft-0.986 sec., 330ft-2.771, 660ft-4.263/165.11 mph, 1,000ft-5.549. Edwards with the second quickest pass of the session, but he will not move up the ladder. Mike Edwards' incremental times: 60ft-0.989 sec., 330ft-2.779, 660ft-4.272/164.95 mph, 1,000ft-5.557.
Left Lane: Jason Line Runs 6.631/208.07, Now #1; Best prior run: 6.624/207.66, Was #1
Right Lane: Ron Krisher Runs 6.675/207.18, Now #4; Best prior run: 6.638/208.33, Was #4
Krisher slows from his time earlier today. Line with the quickest pass of the round...Jason Line's incremental times: 60ft-0.987 sec., 330ft-2.771, 660ft-4.262/164.93 mph, 1,000ft-5.547.
Old 10-29-2011, 05:41 PM
Round 3 Qualifying
Sat, 29 Oct 2011, 02:56 PM
Pro Stock Qualifying Notes, Session #3
By Rick Green
LAS VEGAS - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 11th annual Big O Tires NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Warren Johnson Runs 6.693/207.27, Now #13; No Prior Run
Right Lane: Gordie Rivera Runs 6.799/203.03, Now #14; No Prior Run
Weather conditions: air temperature 70 degrees, relative humidity 20 percent, barometer 28.00 inches, adjusted altitude 3,295 feet, track temperature 96 degrees.
rivera with his quickest pass of the weekend. WJ matches his E.T. from yesterday...Warren Johnson's incremental times: 60ft-1.014 sec., 330ft-2.818, 660ft-4.316/164.33 mph, 1,000ft-5.606.
Left Lane: Ronnie Humphrey Runs 6.639/207.72, Now #5; Best prior run: 6.650/206.76, Was #5
Right Lane: Mark Wolfe Runs 6.657/206.89, Now #9; No Prior Run
Humphrey with his quickest pass of the weekend, but will stay in the number five spot. Ronnie Humphrey's incremental times: 60ft-0.999 sec., 330ft-2.782, 660ft-4.271/165.09 mph, 1,000ft-5.555. Wolfe with his career quickest and fastest pass to move into the field. Mark Wolfe's incremental times: 60ft-0.990 sec., 330ft-2.781, 660ft-4.277/164.71 mph, 1,000ft-5.568.
Left Lane: Grace Howell Runs 6.738/205.22, Now #16; No Prior Run
Right Lane: V. Gaines Runs 6.655/207.27, Now #9; No Prior Run
Howell with her quickest pass to get in the show for now...Grace Howell's incremental times: 60ft-0.997 sec., 330ft-2.821, 660ft-4.337/162.47 mph, 1,000ft-5.640. Gaines gets into the show. V. Gaines' incremental times: 60ft-0.994 sec., 330ft-2.784, 660ft-4.280/164.47 mph, 1,000ft-5.569.
Left Lane: Buddy Perkinson Runs 6.699/205.63, Now #17; No Prior Run
Right Lane: Steve Kent Runs 6.651/207.50, Now #6; No Prior Run
Perkinson got to the finish line first and got in the show, but then when Kent crossed the finish line he bumped Perkinson out. Buddy Perkinson's incremental times: 60ft-1.003 sec., 330ft-2.802, 660ft-4.304/163.53 mph, 1,000ft-5.602.
Steve Kent's incremental times: 60ft-0.996 sec., 330ft-2.786, 660ft-4.278/165.05 mph, 1,000ft-5.566.
Left Lane: Shane Gray Runs 6.641/207.88, Now #6; No Prior Run
Right Lane: Kurt Johnson Runs 6.652/207.53, Now #9; Best prior run: 6.683/206.32, Was #15
Gray with the second quickest pass of the round to get into the top half of the show. Shane Gray's incremental times: 60ft-0.991 sec., 330ft-2.778, 660ft-4.269/165.13 mph, 1,000ft-5.556. Johnson with his quickest pass of the weekend to move up the ladder. Kurt Johnson's incremental times: 60ft-0.990 sec., 330ft-2.781, 660ft-4.277/164.57 mph, 1,000ft-5.566.
Left Lane: Rodger Brogdon Runs 6.632/207.85, Now #3; Best prior run: 6.683/207.18, Was #16
Right Lane: Ron Krisher Runs 6.637/208.20, Now #5; Best prior run: 6.638/208.33, Was #4
These two with the two quickest passes of the round and Brogdon gets off the bump spot and all the way to the number three spot. Rodger Brogdon's incremental times: 60ft-0.993 sec., 330ft-2.775, 660ft-4.264/165.23 mph, 1,000ft-5.549. Krisher with his quickest pass of the weekend, and gets bumped back one spot. Ron Krisher's incremental times: 60ft-0.994 sec., 330ft-2.781, 660ft-4.272/165.23 mph, 1,000ft-5.555.
Left Lane: Vincent Nobile Runs 6.644/207.94, Now #8; Best prior run: 6.655/207.50, Was #12
Right Lane: Greg Stanfield Runs 6.654/207.53, Now #13; Best prior run: 6.669/206.35, Was #15
Nobile with his quickest pass of the weekend to get into the top half of the show. Vincent Nobile's incremental times: 60ft-0.989 sec., 330ft-2.779, 660ft-4.273/164.93 mph, 1,000ft-5.559. Stanfield with his quickest pass of the weekend to move up the ladder two spots.
Left Lane: Larry Morgan Runs 6.633/207.69, Now #6; Best prior run: 6.677/206.86, Was #16
Right Lane: Allen Johnson Runs 6.630/208.33, Now #3; Best prior run: 6.654/208.07, Was #12
Morgan with a great pass to get off the bubble and into the top half of the field. Larry Morgan's incremental times: 60ft-0.994 sec., 330ft-2.774, 660ft-4.264/164.99 mph, 1,000ft-5.549. Johnson with his quickest pass of the weekend to move into the number three spot. Allen Johnson's incremental times: 60ft-0.985 sec., 330ft-2.771, 660ft-4.262/165.09 mph, 1,000ft-5.547.
Left Lane: Mike Edwards Runs 6.594/208.81, Now #1; Best prior run: 6.627/208.33, Was #2
Right Lane: Erica Enders Runs 6.640/207.82, Now #9; Best prior run: 6.652/207.56, Was #12
Enders with her quickest pass of the weekend to move up the ladder. Erica Enders' incremental times: 60ft-0.987 sec., 330ft-2.776, 660ft-4.268/165.13 mph, 1,000ft-5.555. Edwards launched hard and keep it hooked up to go to the number one spot. Edwards sets both ends of the track record. Mike Edwards' incremental times: 60ft-0.983 sec., 330ft-2.759, 660ft-4.242/165.92 mph, 1,000ft-5.518.
Left Lane: Jason Line Runs 6.630/208.49, Now #2; Best prior run: 6.624/207.66, Was #2
Right Lane: Greg Anderson No Time, Now #5; Best prior run: 6.633/208.14, Was #5
Anderson is shut off before he staged the word from the starting line was it was a broken wheelie bar. Line with the second quickest pass of the round and will stay in the number two spot. Jason Line's incremental times: 60ft-0.991 sec., 330ft-2.778, 660ft-4.266/165.40 mph, 1,000ft-5.548.
Old 10-29-2011, 05:51 PM
Final Qualifying
Sat, 29 Oct 2011, 07:44 PM
Pro Stock Qualifying Notes, Final Session
By Rick Green
LAS VEGAS - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 11th annual Big O Tires NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Gordie Rivera Runs 6.810/202.67, Now #20; Best prior run: 6.799/203.03, Was #20
Right Lane: Grace Howell Runs 6.736/204.85, Now #19; Best prior run: 6.738/205.22, Was #19
Howell with her quickest pass of the weekend, but will not get in the show. No help here for Rivera.
Left Lane: Mark Wolfe Runs 11.980/73.11, Now #16; Best prior run: 6.657/206.89, Was #16
Right Lane: Buddy Perkinson Runs 6.859/201.19, Now #18; Best prior run: 6.699/205.63, Was #18
Wolfe with problems early and he pushes in the clutch. He holds on to the number 16 spot. No help here for Perkinson.
Left Lane: V. Gaines Runs 7.000/167.47, Now #15; Best prior run: 6.655/207.27, Was #15
Right Lane: Warren Johnson Runs 6.701/206.07, Now #17; Best prior run: 6.693/207.27, Was #17
WJ slows and he will not get in the show. Gaines with a puff of smoke on the top end, and he pushes in the clutch early.
Left Lane: Greg Stanfield Runs 6.676/206.89, Now #14; Best prior run: 6.654/207.53, Was #14
Right Lane: Vincent Nobile Runs 6.664/207.50, Now #11; Best prior run: 6.644/207.94, Was #11
The two quickest runs on the round, so far. Neither driver will improve.
Left Lane: Kurt Johnson Runs 6.698/206.70, Now #13; Best prior run: 6.652/207.53, Was #13
Right Lane: Shane Gray Runs 6.658/207.69, Now #10; Best prior run: 6.641/207.88, Was #10
Gray now with the quickest pass of the round, but he will not improve. Kurt Johnson's incremental times: 60ft-1.012 sec., 330ft-2.810, 660ft-4.313/163.81 mph, 1,000ft-5.607.
Shane Gray's incremental times: 60ft-0.989 sec., 330ft-2.784, 660ft-4.280/164.85 mph, 1,000ft-5.571.
Left Lane: Steve Kent Runs 6.673/206.95, Now #12; Best prior run: 6.651/207.50, Was #12
Right Lane: Ronnie Humphrey Runs 6.661/207.02, Now #8; Best prior run: 6.639/207.72, Was #8
Humphrey with the second quickest pass of the round. Ronnie Humphrey's incremental times: 60ft-1.000 sec., 330ft-2.788, 660ft-4.284/164.73 mph, 1,000ft-5.574.
Left Lane: Erica Enders Runs 6.648/207.34, Now #9; Best prior run: 6.640/207.82, Was #9
Right Lane: Larry Morgan Runs 6.653/207.91, Now #6; Best prior run: 6.633/207.69, Was #6
Enders with the quickest pass of the round. Erica Enders' incremental times: 60ft-0.991 sec., 330ft-2.780, 660ft-4.274/164.69 mph, 1,000ft-5.562.
Larry Morgan's incremental times: 60ft-0.995 sec., 330ft-2.783, 660ft-4.279/164.59 mph, 1,000ft-5.567.
Left Lane: Ron Krisher Runs 6.667/207.15, Now #7; Best prior run: 6.637/208.20, Was #7
Right Lane: Rodger Brogdon Runs 6.663/207.24, Now #4; Best prior run: 6.632/207.85, Was #4
Ron Krisher's incremental times: 60ft-0.994 sec., 330ft-2.792, 660ft-4.291/164.33 mph, 1,000ft-5.580.
Rodger Brogdon's incremental times: 60ft-0.998 sec., 330ft-2.789, 660ft-4.286/164.61 mph, 1,000ft-5.576.
Left Lane: Greg Anderson Runs 6.672/208.07, Now #5; Best prior run: 6.633/208.14, Was #5
Right Lane: Jason Line Runs 6.628/208.14, Now #2; Best prior run: 6.624/207.66, Was #2
Line launched hard and keep it hooked up to make the quickest pass of the round. Jason Line's incremental times: 60ft-0.981 sec., 330ft-2.766, 660ft-4.259/165.11 mph, 1,000ft-5.544.
Greg Anderson's incremental times: 60ft-1.001 sec., 330ft-2.803, 660ft-4.300/164.49 mph, 1,000ft-5.588.
Left Lane: Allen Johnson Runs 15.157/54.80, Now #3; Best prior run: 6.630/208.33, Was #3
Right Lane: Mike Edwards Runs 6.620/208.84, Now #1; Best prior run: 6.594/208.81, Was #1
Johnson made a quick move toward the wall and pushed in the clutch. Edwards with another great pass with the quickest pass of the round and will hold on to the number one spot. This is the 47th time Edwards has qualified number one.
Old 10-31-2011, 05:05 AM
Summary of Eliminations
Sun, 30 Oct 2011, 10:02 PM
Summary of Eliminations in Pro Stock
LAS VEGAS - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 11th annual Big O Tires NHRA Nationals:
Round 1:
Ronnie Humphrey, Jacksonville NC, '09 GXP, Left lane, (0.040) 6.665 206.76 def. Erica Enders, NewOrleans LA, '10 Cobalt, (0.007) 12.632 68.01
Ron Krisher, Warren OH, '09 GXP, Left lane, (-0.004) 6.644 207.66 def. Shane Gray, Denver NC, '09GXP, (-0.015 foul) 6.666 207.02
Larry Morgan, Newark OH, '11 Mustang, Left lane, (0.004) 6.658 207.18 def. Vincent Nobile, DixHills NY, '11 Avenger, (0.004) 6.676 207.08
Greg Anderson, Mooresville NC, '09 GXP, Left lane, (0.077) 6.642 208.10 def. Steve Kent, Lottie LA,'09 GXP, (0.053) 6.680 206.48
Kurt Johnson, Sugar Hill GA, '09 GXP, Right lane, (0.027) 6.668 206.70 def. Rodger Brogdon, TomballTX, '09 GXP, (0.042) 6.662 206.92
Mike Edwards, Coweta OK, '09 GXP, Left lane, (0.090) 6.628 208.65 def. Mark Wolfe, Marysville WA,'11 Mustang, (0.098) 6.715 205.32
Jason Line, Mooresville NC, '09 GXP, Left lane, (0.076) 6.630 207.75 def. V. Gaines, Lakewood CO,'11 Avenger, (0.009) 6.697 206.07
Allen Johnson, Greeneville TN, '11 Avenger, Left lane, (0.030) 6.648 207.56 def. Greg Stanfield,Bossier City LA, '09 GXP, (0.013) 6.699 206.76
Round 2:
A Johnson, Left lane, (0.041) 6.680 207.56 def. L Morgan, (0.041) 6.716 206.83
G Anderson, Left lane, (0.030) 6.667 207.53 def. K Johnson, (0.026) 6.696 206.51
J Line, Left lane, (0.032) 6.652 207.34 def. R Krisher, (-0.103 foul) 6.801 190.35
M Edwards, Left lane, (0.030) 6.652 208.17 def. R Humphrey, (0.076) 6.717 206.61
Round 3:
A Johnson, Right lane, (0.026) 6.674 207.53 def. J Line, (-0.013 foul) 6.650 207.08
M Edwards, Left lane, (0.001) 6.663 208.17 def. G Anderson, (0.035) 6.646 207.78
Round 4:
M Edwards, Left lane, (0.029) 6.641 208.30 def. A Johnson, (0.034) 6.668 208.01
Low ET: Mike Edwards 6.594 seconds
Top Speed: Mike Edwards 208.84 MPH
MReeves
Funny Car
10-31-2011 05:19 AM
MReeves
Stock Eliminator
10-30-2011 11:14 AM
MReeves
Super Stock
10-30-2011 11:12 AM
MReeves
Super Gas
10-29-2011 05:59 PM
MReeves
Funny Car
04-19-2010 08:31 AM
Quick Reply: NHRA Big O Tries Nationals Las Vegas
