NHRA ORiley Nationals Charlotte
Old 09-16-2011, 04:39 PM
Fri, 16 Sep 2011, 05:20 PM
Pro Stock Qualifying Notes, Session #1
By Rick Green
CONCORD, N.C. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual O'Reilly Auto Parts NHRA Nationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Right Lane: Wally Stroupe Runs 6.801/202.24, Now #1
Weather conditions: air temperature 63 degrees, relative humidity 49 percent, barometer 29.58 inches, adjusted altitude 1,139 feet, track temperature 79 degrees.
Stroupe with Elite Motorsports this weekend and makes his first pass of the weekend...he makes his career best pass. Wally Stroupe's incremental times: 60ft-1.014 sec., 330ft-2.844, 660ft-4.370/161.67 mph, 1,000ft-5.689.
Left Lane: Grace Howell Runs 17.473/35.89, Now #3
Right Lane: Robert Patrick Runs 13.898/61.59, Now #2
Howell shook hard and clicked it off...Patrick also shook and shut it off.
Left Lane: Bob Benza Runs 13.478/63.41, Now #3
Right Lane: Steve Kent Runs 6.581/210.80, Now #1
Benza pushes the clutch in early...Kent launched hard and keep it hooked up. Steve Kent's incremental times: 60ft-0.997 sec., 330ft-2.770, 660ft-4.242/167.84 mph, 1,000ft-5.512.
Left Lane: Buddy Perkinson Runs 6.581/210.21, Now #2
Right Lane: Warren Johnson Runs 21.893/28.80, Now #7
Johnson bogged as soon as he let the clutch out. Perkinson with his career best pass and tied Kent for low E.T. but will be second because Kent was faster. Buddy Perkinson's incremental times: 60ft-0.989 sec., 330ft-2.762, 660ft-4.237/167.43 mph, 1,000ft-5.509.
Left Lane: Kurt Johnson Runs 6.550/211.43, Now #1
Right Lane: V. Gaines Runs 6.579/210.64, Now #2
A couple great looking passes as they go to the number one and two spots...Kurt Johnson's incremental times: 60ft-0.981 sec., 330ft-2.747, 660ft-4.217/167.86 mph, 1,000ft-5.483.
V. Gaines' incremental times: 60ft-0.991 sec., 330ft-2.769, 660ft-4.242/167.47 mph, 1,000ft-5.511.
Left Lane: Larry Morgan Runs 6.555/210.83, Now #2
Right Lane: Ronnie Humphrey Runs 6.564/211.46, Now #3
Morgan with a really good pass to go to the number two spot. Larry Morgan's incremental times: 60ft-0.988 sec., 330ft-2.752, 660ft-4.221/167.57 mph, 1,000ft-5.488. humphrey is right there with him to the number three spot. Ronnie Humphrey's incremental times: 60ft-1.002 sec., 330ft-2.770, 660ft-4.235/168.45 mph, 1,000ft-5.499.
Left Lane: Ron Krisher Runs 6.589/210.05, Now #8
Right Lane: Shane Gray Runs 6.572/209.95, Now #4
Gray with a nice pass to go to the number four spot. Shane Gray's incremental times: 60ft-0.980 sec., 330ft-2.751, 660ft-4.227/167.45 mph, 1,000ft-5.500. Ron Krisher's incremental times: 60ft-0.977 sec., 330ft-2.759, 660ft-4.241/166.50 mph, 1,000ft-5.516.
Left Lane: Greg Stanfield Runs 6.571/209.75, Now #5
Right Lane: Rodger Brogdon Runs 6.571/211.16, Now #4
These two run identical E.T.s, but Brogdon gets the higher spot based on the his higher speed. Greg Stanfield's incremental times: 60ft-0.981 sec., 330ft-2.750, 660ft-4.225/167.55 mph, 1,000ft-5.497.
Rodger Brogdon's incremental times: 60ft-0.994 sec., 330ft-2.767, 660ft-4.237/168.22 mph, 1,000ft-5.504.
Left Lane: Allen Johnson Runs 6.541/211.99, Now #1
Right Lane: Erica Enders Runs 6.574/211.33, Now #8
Johnson with a great pass and he goes to the number one spot...Allen Johnson's incremental times: 60ft-0.988 sec., 330ft-2.750, 660ft-4.215/168.70 mph, 1,000ft-5.479. Enders was a little loose off the starting line, but still goes to the number eight. Erica Enders' incremental times: 60ft-0.997 sec., 330ft-2.772, 660ft-4.242/168.05 mph, 1,000ft-5.508.
Left Lane: Vincent Nobile Runs 6.565/211.86, Now #6
Right Lane: Mike Edwards Runs 6.540/211.93, Now #1
Nobile with a real nice pass to get into the top half of the show. Vincent Nobile's incremental times: 60ft-0.987 sec., 330ft-2.763, 660ft-4.235/168.03 mph, 1,000ft-5.501. Edwards launched hard and keep it hooked up to go to the number one spot. Mike Edwards' incremental times: 60ft-0.977 sec., 330ft-2.741, 660ft-4.209/168.09 mph, 1,000ft-5.475.
Left Lane: Jason Line Runs 6.510/212.56, Now #1
Right Lane: Greg Anderson Runs 6.515/212.69, Now #2
These two both launched hard and they both keep them hooked up to go to the top of the list. Line goes to the number one spot and Anderson goes to the number two spot. Jason Line's incremental times: 60ft-0.977 sec., 330ft-2.735, 660ft-4.194/169.25 mph, 1,000ft-5.451.
Greg Anderson's incremental times: 60ft-0.982 sec., 330ft-2.743, 660ft-4.201/169.32 mph, 1,000ft-5.457.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old 09-17-2011, 02:30 PM
Round 2 Qualifying
Fri, 16 Sep 2011, 09:04 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
CONCORD, N.C. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual O'Reilly Auto Parts NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Warren Johnson Runs 7.526/205.85, Now #18; Best prior run: 21.893/28.80, Was #21
That was weird...it appeared the car spun hard and then it was like he did a quick pedal job...
Left Lane: Robert Patrick Runs 6.624/208.59, Now #17; Best prior run: 13.898/61.59, Was #20
Right Lane: Grace Howell Runs 10.592/115.75, Now #20; Best prior run: 17.473/35.89, Was #21
Howell shook and shut off. Patrick with his career quickest and fastest pass, but will not get in the show. Robert Patrick's incremental times: 60ft-0.995 sec., 330ft-2.779, 660ft-4.264/166.09 mph, 1,000ft-5.545.
Left Lane: Wally Stroupe Runs 11.874/73.94, Now #19; Best prior run: 6.801/202.24, Was #18
Right Lane: Bob Benza Runs 6.652/201.16, Now #18; Best prior run: 13.478/63.41, Was #21
Stroupe shook and shut off...Benza gets down the track, but not in the show.
Left Lane: Steve Kent Runs 6.646/195.59, Now #14; Best prior run: 6.581/210.80, Was #14
Right Lane: Ron Krisher Runs 7.344/142.13, Now #16; Best prior run: 6.589/210.05, Was #16
Krisher shook and shut off. Kent with the second quickest pass of this session...Steve Kent's incremental times: 60ft-0.998 sec., 330ft-2.782, 660ft-4.262/166.79 mph, 1,000ft-5.539.
Left Lane: V. Gaines Runs 6.583/201.85, Now #13; Best prior run: 6.579/210.64, Was #13
Right Lane: Buddy Perkinson Runs 6.583/210.21, Now #15; Best prior run: 6.581/210.21, Was #15
These two run identical E.T.s and they are the two quickest of the round, so far.
Left Lane: Erica Enders Runs 6.551/211.49, Now #6; Best prior run: 6.574/211.33, Was #12
Right Lane: Greg Stanfield Runs 6.579/210.05, Now #11; Best prior run: 6.571/209.75, Was #10
Stanfield is just a few ticks off his earlier qualifying time...Enders launched hard and keep it hooked up to run the quickest of the round and she moved into the top half of the show. Erica Enders' incremental times: 60ft-0.983 sec., 330ft-2.751, 660ft-4.219/168.20 mph, 1,000ft-5.485.
Left Lane: Shane Gray Runs 6.603/209.01, Now #12; Best prior run: 6.572/209.95, Was #12
Right Lane: Vincent Nobile Runs 6.561/210.83, Now #8; Best prior run: 6.565/211.86, Was #9
no help here for Gray and he stays in the number 12 spot. Shane Gray's incremental times: 60ft-0.978 sec., 330ft-2.764, 660ft-4.247/166.27 mph, 1,000ft-5.526. Nobile with his quickest pass of the day and he moves up the ladder one spot. Vincent Nobile's incremental times: 60ft-0.981 sec., 330ft-2.754, 660ft-4.226/167.49 mph, 1,000ft-5.493.
Left Lane: Rodger Brogdon Runs 6.582/210.44, Now #10; Best prior run: 6.571/211.16, Was #10
Right Lane: Larry Morgan Runs 6.548/211.20, Now #5; Best prior run: 6.555/210.83, Was #7
Morgan with the quickest pass of the session and he moves up to the number five spot. Larry Morgan's incremental times: 60ft-0.981 sec., 330ft-2.747, 660ft-4.214/168.43 mph, 1,000ft-5.481. No help here for Brogdon....Rodger Brogdon's incremental times: 60ft-0.990 sec., 330ft-2.766, 660ft-4.241/167.41 mph, 1,000ft-5.512.
Left Lane: Ronnie Humphrey Runs 6.534/211.76, Now #3; Best prior run: 6.564/211.46, Was #9
Right Lane: Kurt Johnson Runs 6.546/211.06, Now #6; Best prior run: 6.550/211.43, Was #6
Humphrey with the quickest pass of the session and he moves up to the number three spot. Ronnie Humphrey's incremental times: 60ft-0.986 sec., 330ft-2.750, 660ft-4.212/168.70 mph, 1,000ft-5.472. Johnson improves, the second quickest of the session, but will not move up the ladder. Kurt Johnson's incremental times: 60ft-0.972 sec., 330ft-2.740, 660ft-4.211/168.09 mph, 1,000ft-5.478.
Left Lane: Mike Edwards Runs 6.550/211.26, Now #5; Best prior run: 6.540/211.93, Was #4
Right Lane: Allen Johnson Runs 6.529/211.79, Now #3; Best prior run: 6.541/211.99, Was #5
Johnson with the quickest pass of the session to move up to third on the ladder. Allen Johnson's incremental times: 60ft-0.972 sec., 330ft-2.733, 660ft-4.199/168.45 mph, 1,000ft-5.464. Edwards with a great short time, but then slows from his earlier time. Mike Edwards' incremental times: 60ft-0.967 sec., 330ft-2.737, 660ft-4.211/167.66 mph, 1,000ft-5.481.
Left Lane: Greg Anderson Runs 10.010/91.06, Now #2; Best prior run: 6.515/212.69, Was #2
Right Lane: Jason Line Runs 6.520/212.66, Now #1; Best prior run: 6.510/212.56, Was #1
Anderson with problems early and he pushes in the clutch. Line with the quickest pass of the session... Jason Line's incremental times: 60ft-0.981 sec., 330ft-2.741, 660ft-4.203/168.77 mph, 1,000ft-5.460.
Old 09-17-2011, 02:34 PM
Round 3 Qualifying
Sat, 17 Sep 2011, 12:16 PM
Pro Stock Qualifying Notes, Session #3
By Rick Green
CONCORD, N.C. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual O'Reilly Auto Parts NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Right Lane: Robert Patrick Runs 6.625/208.52, Now #13; No Prior Run
Weather conditions: air temperature 62 degrees, relative humidity 67 percent, barometer 29.63 inches, adjusted altitude 1,082 feet, track temperature 73 degrees.
Patrick with his career best pass here...Robert Patrick's incremental times: 60ft-0.984 sec., 330ft-2.772, 660ft-4.260/165.88 mph, 1,000ft-5.544.
Left Lane: Grace Howell Runs 16.805/27.92, Now #15; No Prior Run
Right Lane: Wally Stroupe Runs 8.247/119.86, Now #14; No Prior Run
Howell with problems right off the starting line and she pushes in the clutch. Stroupe starts to shake and he shuts it off.
Left Lane: Ron Krisher Runs 6.576/210.37, Now #13; No Prior Run
Right Lane: Greg Anderson Runs 6.513/212.29, Now #2; Best prior run: 6.515/212.69, Was #2
Krisher with his quickest pass of the weekend to get in the show. Ron Krisher's incremental times: 60ft-0.986 sec., 330ft-2.757, 660ft-4.233/167.07 mph, 1,000ft-5.506. Anderson launched hard and keep it hooked up to run his quickest pass of the weekend...he will stay in the number two spot. Greg Anderson's incremental times: 60ft-0.978 sec., 330ft-2.733, 660ft-4.193/169.02 mph, 1,000ft-5.453.
Left Lane: Bob Benza Runs 6.669/208.30, Now #16; No Prior Run
Right Lane: Warren Johnson Runs 6.554/210.83, Now #9; No Prior Run
Benza gets in the show for now...Bob Benza's incremental times: 60ft-0.981 sec., 330ft-2.792, 660ft-4.296/164.51 mph, 1,000ft-5.586. Johnson with his quickest pass of the weekend and goes to the number nine. Warren Johnson's incremental times: 60ft-0.980 sec., 330ft-2.746, 660ft-4.217/167.93 mph, 1,000ft-5.486.
Left Lane: Buddy Perkinson Runs 6.584/209.95, Now #16; No Prior Run
Right Lane: Steve Kent Runs 6.571/211.03, Now #12; No Prior Run
Perkinson gets in the show and bumps out Benza. Buddy Perkinson's incremental times: 60ft-0.983 sec., 330ft-2.760, 660ft-4.237/167.36 mph, 1,000ft-5.511. Kent with his quickest pass of the weekend to get in the show. Steve Kent's incremental times: 60ft-0.985 sec., 330ft-2.757, 660ft-4.231/167.66 mph, 1,000ft-5.502.
Left Lane: Greg Stanfield Runs 6.622/209.10, Now #13; Best prior run: 6.571/209.75, Was #13
Right Lane: Shane Gray Runs 7.579/124.69, Now #14; Best prior run: 6.572/209.95, Was #14
No help here for Stanfield and he will stay 13th now....Greg Stanfield's incremental times: 60ft-0.989 sec., 330ft-2.770, 660ft-4.260/165.64 mph, 1,000ft-5.543. Gray with problems early and pushes in the clutch.
Left Lane: Vincent Nobile Runs 6.574/211.36, Now #10; Best prior run: 6.561/210.83, Was #10
Right Lane: V. Gaines Runs 6.602/209.72, Now #17; No Prior Run
Nobile slows from yesterday...Vincent Nobile's incremental times: 60ft-0.982 sec., 330ft-2.762, 660ft-4.238/167.36 mph, 1,000ft-5.507. Gaines slows from yesterday and he will not get in the show. V. Gaines' incremental times: 60ft-0.991 sec., 330ft-2.775, 660ft-4.255/166.99 mph, 1,000ft-5.529.
Left Lane: Larry Morgan Runs 6.621/210.37, Now #7; Best prior run: 6.548/211.20, Was #7
Right Lane: Rodger Brogdon Runs 17.719/33.36, Now #11; Best prior run: 6.571/211.16, Was #11
Brogdon shook right off the starting line and pushed in the clutch. Morgan slows from yesterday. Larry Morgan's incremental times: 60ft-0.986 sec., 330ft-2.794, 660ft-4.274/166.76 mph, 1,000ft-5.549.
Left Lane: Kurt Johnson Runs 6.581/210.54, Now #6; Best prior run: 6.546/211.06, Was #6
Right Lane: Erica Enders Runs 6.558/211.03, Now #8; Best prior run: 6.551/211.49, Was #8
Johnson slows from yesterday....Kurt Johnson's incremental times: 60ft-0.978 sec., 330ft-2.758, 660ft-4.237/167.01 mph, 1,000ft-5.510. Enders with the third quickest pass of the session...Erica Enders' incremental times: 60ft-0.988 sec., 330ft-2.756, 660ft-4.224/168.09 mph, 1,000ft-5.491.
Left Lane: Allen Johnson Runs 6.543/211.79, Now #3; Best prior run: 6.529/211.79, Was #3
Right Lane: Mike Edwards No Time, Now #5; Best prior run: 6.540/211.93, Was #5
Edwards shook hard right at the hit and it appeared he broke something as he pulled over by the wall. Johnson with the second quickest pass of the session, but doesn't improve on his time from yesterday. Allen Johnson's incremental times: 60ft-0.977 sec., 330ft-2.744, 660ft-4.213/168.28 mph, 1,000ft-5.479.
Left Lane: Jason Line Runs 6.518/212.59, Now #1; Best prior run: 6.510/212.56, Was #1
Right Lane: Ronnie Humphrey Runs 6.543/211.16, Now #4; Best prior run: 6.534/211.76, Was #4
Humphrey with another good looking pass, the fourth quickest pass of the round. Ronnie Humphrey's incremental times: 60ft-0.980 sec., 330ft-2.750, 660ft-4.215/168.64 mph, 1,000ft-5.478. Line with the second quickest pass of the session....Jason Line's incremental times: 60ft-0.980 sec., 330ft-2.739, 660ft-4.200/168.96 mph, 1,000ft-5.458. Line holds on to the number one spot.
Old 09-17-2011, 02:38 PM
Final Qualifying
Sat, 17 Sep 2011, 03:02 PM
Pro Stock Qualifying Notes, Final Session
By Rick Green
CONCORD, N.C. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual O'Reilly Auto Parts NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Wally Stroupe Runs 6.824/201.76, Now #20; Best prior run: 8.247/119.86, Was #20
Weather conditions: air temperature 67 degrees, relative humidity 60 percent, barometer 29.62 inches, adjusted altitude 1,475 feet, track temperature 79 degrees.
Stroupe will not get in the show...
Left Lane: Robert Patrick Runs 6.610/208.52, Now #18; Best prior run: 6.625/208.52, Was #18
Right Lane: Grace Howell Runs 17.018/29.97, Now #21; Best prior run: 16.805/27.92, Was #21
Howell with a lot of tire shake and she pushes in the clutch. Patrick with his quickest pass of the weekend, but he will not get in the show. Robert Patrick's incremental times: 60ft-0.978 sec., 330ft-2.760, 660ft-4.246/165.86 mph, 1,000ft-5.529.
Left Lane: V. Gaines Runs 6.575/210.28, Now #15; Best prior run: 6.602/209.72, Was #17
Right Lane: Bob Benza Runs 6.620/208.68, Now #19; Best prior run: 6.669/208.30, Was #19
Benza with his quickest pass of the weekend, but he will not get in the show. Bob Benza's incremental times: 60ft-0.997 sec., 330ft-2.779, 660ft-4.262/166.35 mph, 1,000ft-5.542. Gaines with his quickest pass of the weekend to get in the show. V. Gaines' incremental times: 60ft-0.979 sec., 330ft-2.754, 660ft-4.232/166.97 mph, 1,000ft-5.503.
Left Lane: Shane Gray Runs 6.577/209.49, Now #15; Best prior run: 6.572/209.95, Was #14
Right Lane: Buddy Perkinson Runs 6.567/210.47, Now #11; Best prior run: 6.584/209.95, Was #17
Perkinson just got bumped out and he makes his career quickest pass to get in the show. Buddy Perkinson's incremental times: 60ft-0.978 sec., 330ft-2.750, 660ft-4.224/167.59 mph, 1,000ft-5.496. Gray with another good pass, but doesn't improve. Shane Gray's incremental times: 60ft-0.977 sec., 330ft-2.747, 660ft-4.225/167.14 mph, 1,000ft-5.501.
Left Lane: Steve Kent Runs 6.571/210.47, Now #13; Best prior run: 6.571/211.03, Was #13
Right Lane: Ron Krisher Runs 6.585/206.76, Now #17; Best prior run: 6.576/210.37, Was #17
Kent matches his best qualifying time...Steve Kent's incremental times: 60ft-0.983 sec., 330ft-2.753, 660ft-4.227/167.34 mph, 1,000ft-5.499. Krisher will not get in the show...
Left Lane: Rodger Brogdon Runs 6.574/210.50, Now #12; Best prior run: 6.571/211.16, Was #12
Right Lane: Greg Stanfield Runs 6.583/209.69, Now #14; Best prior run: 6.571/209.75, Was #14
No help here for either driver...Rodger Brogdon's incremental times: 60ft-0.986 sec., 330ft-2.759, 660ft-4.233/167.66 mph, 1,000ft-5.504.
Greg Stanfield's incremental times: 60ft-0.988 sec., 330ft-2.761, 660ft-4.238/167.49 mph, 1,000ft-5.510.
Left Lane: Warren Johnson Runs 6.574/210.31, Now #9; Best prior run: 6.554/210.83, Was #9
Right Lane: Vincent Nobile Runs 10.778/83.24, Now #10; Best prior run: 6.561/210.83, Was #10
Nobile was out of the groove early over by the centerline before he clicked it off. Johnson will not improve...Warren Johnson's incremental times: 60ft-0.980 sec., 330ft-2.755, 660ft-4.231/167.16 mph, 1,000ft-5.503.
Left Lane: Erica Enders Runs 6.555/211.13, Now #8; Best prior run: 6.551/211.49, Was #8
Right Lane: Larry Morgan Runs 6.563/210.50, Now #7; Best prior run: 6.548/211.20, Was #7
Enders with another good pass, but will not improve...Erica Enders' incremental times: 60ft-0.982 sec., 330ft-2.750, 660ft-4.221/167.99 mph, 1,000ft-5.489. Morgan is straight down the groove, but he will not improve...Larry Morgan's incremental times: 60ft-0.988 sec., 330ft-2.753, 660ft-4.223/168.05 mph, 1,000ft-5.493.
Left Lane: Mike Edwards Runs 6.584/210.67, Now #5; Best prior run: 6.540/211.93, Was #5
Right Lane: Kurt Johnson Runs 6.589/210.97, Now #6; Best prior run: 6.546/211.06, Was #6
these two were side-by-side all the way down the track...Mike Edwards' incremental times: 60ft-0.984 sec., 330ft-2.766, 660ft-4.244/167.26 mph, 1,000ft-5.515.
Kurt Johnson's incremental times: 60ft-1.006 sec., 330ft-2.778, 660ft-4.250/167.70 mph, 1,000ft-5.520.
Left Lane: Ronnie Humphrey Runs 6.538/211.00, Now #4; Best prior run: 6.534/211.76, Was #4
Right Lane: Allen Johnson Runs 6.551/211.39, Now #3; Best prior run: 6.529/211.79, Was #3
A couple great runs here as Humphrey runs the quickest of the session and Johnson runs the second quickest pass of the round. Ronnie Humphrey's incremental times: 60ft-0.980 sec., 330ft-2.741, 660ft-4.206/168.49 mph, 1,000ft-5.472.
Allen Johnson's incremental times: 60ft-0.984 sec., 330ft-2.749, 660ft-4.218/168.14 mph, 1,000ft-5.485.
Left Lane: Greg Anderson Runs 6.521/211.83, Now #2; Best prior run: 6.513/212.29, Was #2
Right Lane: Jason Line Runs 6.558/212.66, Now #1; Best prior run: 6.510/212.56, Was #1
Line with a little wiggle right off the line...but he holds on to the number one spot. Jason Line's incremental times: 60ft-0.985 sec., 330ft-2.770, 660ft-4.237/168.77 mph, 1,000ft-5.498. This is Line's 22nd career and fifth this season No. 1 position. Anderson with the quickest pass of the round and he will stay number two. Greg Anderson's incremental times: 60ft-0.973 sec., 330ft-2.735, 660ft-4.198/168.83 mph, 1,000ft-5.459.
Old 09-19-2011, 08:39 AM
Summary of Eliminations
Sun, 18 Sep 2011, 07:58 PM
Summary of Eliminations in Pro Stock
CONCORD, N.C. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, Fourth annual O'Reilly Auto Parts NHRA Nationals:
Round 1:
Erica Enders, New Orleans LA, '10 Cobalt, Right lane, (0.030) 6.568 210.80 def. Warren Johnson,Sugar Hill GA, '09 GXP, (0.088) 6.617 209.43
Vincent Nobile, Dix Hills NY, '11 Avenger, Left lane, (0.007) 6.558 211.20 def. Larry Morgan,Newark OH, '11 Mustang, (0.031) 6.748 180.65
Kurt Johnson, Sugar Hill GA, '09 GXP, Right lane, (0.035) 6.561 210.21 def. Buddy Perkinson,Hopewell VA, '11 Mustang, (0.050) 6.608 209.46
Shane Gray, Denver NC, '09 GXP, Left lane, (0.034) 6.607 209.01 def. Greg Anderson, Mooresville NC,'09 GXP, (0.079) 6.571 205.47
Jason Line, Mooresville NC, '09 GXP, Right lane, (0.023) 6.524 212.43 def. V. Gaines, Lakewood CO,'11 Avenger, (0.048) 11.339 78.87
Greg Stanfield, Bossier City LA, '09 GXP, Left lane, (0.001) 6.592 209.39 def. Allen Johnson,Greeneville TN, '11 Avenger, (0.020) 14.132 61.39
Steve Kent, Lottie LA, '09 GXP, Left lane, (0.057) 6.569 210.11 def. Ronnie Humphrey, JacksonvilleNC, '09 GXP, (0.158) 6.586 210.67
Mike Edwards, Coweta OK, '09 GXP, Right lane, (0.017) 6.585 210.60 def. Rodger Brogdon, Tomball TX,'09 GXP, (0.031) 6.669 209.75
Round 2:
S Kent, Right lane, (0.041) 6.556 210.14 def. M Edwards, (0.005) 6.895 163.77
K Johnson, Right lane, (0.013) 6.579 209.82 def. G Stanfield, (0.027) 6.597 209.01
V Nobile, Right lane, (0.011) 6.575 210.57 def. S Gray, (0.045) 6.594 209.20
J Line, Right lane, (0.021) 6.525 212.09 def. E Enders, (-0.017 foul) 6.551 210.93
Round 3:
K Johnson, Left lane, (0.031) 6.550 209.82 def. V Nobile, (0.004) 6.586 210.87
J Line, Right lane, (0.043) 6.521 211.63 def. S Kent, (0.016) 6.559 210.08
Round 4:
K Johnson, Left lane, (0.041) 6.545 210.97 def. J Line, (-0.003 foul) 6.528 212.06
Low ET: Jason Line 6.510 seconds
Top Speed: Greg Anderson 212.69 MPH
MReeves
Super Gas
04-14-2012 09:11 AM
MReeves
Funny Car
09-19-2011 08:47 AM
MReeves
Stock Eliminator
09-17-2011 05:32 PM
MReeves
Super Stock
09-17-2011 05:27 PM
MReeves
Super Gas
09-16-2011 04:33 PM
Quick Reply: NHRA ORiley Nationals Charlotte
