22" to 26" radiator
Old 03-04-2014, 04:13 PM
mrzods13's Avatar
22" to 26" radiator
I am most likely buying a new aluminum radiator for my 1968 chrysler newport with the 383 non ac. I have a 22 inch in there now and the one I want is 26" and it is made in usa not china. My question is will I need a different radiator support I am wondering if the 26" will fit.
Old 03-04-2014, 05:17 PM
Mr.4spd's Avatar
If it's a crossflow (most aluminum rads are) the core will still be close to 22" and your support won't hinder airflow. The stock mounts will likely not work, but I'll bet you can fab something up no prob.
mrzods13 (03-06-2014)
Old 03-05-2014, 01:01 AM
mrzods13's Avatar
It is downflow
Old 03-05-2014, 03:19 AM
Mr.4spd's Avatar
Hopefully the stock support will work for you then, it's not a bolt in part. Lots of spot-welds to r&r.
Old 03-05-2014, 06:28 AM
Call Charlie...
aluminum radiators
I have priced all the aluminum radiators @ 365.00 + shipping, A-B-C-E mopars, small or big block engines.
Transmission cooler is built in just like the factory radiators, and there are brackets built in for the fan schrod.
Please feel free to call me @ 727-271-5068
MOPAR CHARLIE
7 days a week 9am-6pm
located in sunny florida
thanks for the replys, and thanks for the ad
Old 03-05-2014, 09:34 AM
mrzods13's Avatar
I was thinking of a griffin but $568 is a little steep. I am not buying a champion thats for sure.
Old 03-05-2014, 01:27 PM
mrzods13's Avatar
Called up Mopar Charlie. Ordered a radiator from him. Griffins are 2 row 1 inch and so are his and they are made in the USA . Can't wait to get it. Thanks Charlie.
Old 03-05-2014, 02:20 PM
Hope Mopar Charlie Gave you the Good Guy Price?
Old 03-05-2014, 02:57 PM
mrzods13's Avatar
$400 shipped
mrzods13's Avatar
I didnt mention I found him on the forum
Old 03-05-2014, 03:54 PM
i hear good/bad on the champion. some folks love em, some folks don't.
Old 03-05-2014, 04:28 PM
mrzods13's Avatar
didnt want to take a chance with champion. too many mixed reviews
Old 03-05-2014, 09:23 PM
moparted's Avatar
a c body radiator support is bolted in but requires fender removal etc to change
Old 03-06-2014, 04:49 AM
mrzods13's Avatar
He said the driver side will bolt right on, so all I have to do is make new holes for the passenger side and get the clips the bolts screw into. Also i was looking at electric fans, would one 16 inch fan be enough or should I do 2 12's, I don't think 2 14's will fit at a diagonal angle. I have seen Zirgo and flexalite brands.
Old 03-06-2014, 08:54 AM
I'm Not a big fan of electric fans... In some cases you must use them, but I like The good old Mopar Viscous Fan....
http://chucker54.stores.yahoo.net/viscousfan.html
Old 03-06-2014, 03:45 PM
mrzods13's Avatar
I was looking at these from summit but I don't know if I could fit them both on the 26",maybe diagonal.
http://www.ebay.com/itm/2-Flex-a-lit...9bd2f0&vxp=mtr
Old 03-06-2014, 06:46 PM
On the ones I do Run a fan on... I like to add this controller...
http://www.flex-a-lite.com/accessori...ontroller.html
mrzods13 (03-07-2014)
Old 03-07-2014, 09:44 PM
mrzods13's Avatar
Do I really need another support being that mine was a 22" core?
Old 03-07-2014, 09:58 PM
moparted's Avatar
I have a 66 Newport with a 69 hp 440 using a 22 champion radiator with a fan shroud.
Old 03-07-2014, 10:03 PM
mrzods13's Avatar
I already bought a radiator from mopar charlie but all he sells is 26" so I have to wing it
Old 03-09-2014, 01:25 PM
mrzods13's Avatar
I was looking at this fan http://www.jegs.com/i/JEGS+Performan...2110K/10002/-1
Old 03-09-2014, 07:24 PM
moparted's Avatar
USE THE BELT DRIVEN FAN
Old 03-17-2014, 05:47 PM
mrzods13's Avatar
Well since no one has posted any pictures of mopar charlies radiators I figured I would share mine.
Size:  69.8 KBName:  20140317_121218.jpg
Size:  50.9 KBName:  20140317_202806.jpg
Size:  86.8 KBName:  20140317_202823.jpg
Size:  117.5 KBName:  20140317_202853.jpg
Size:  75.9 KBName:  20140317_202858.jpg
Size:  54.6 KBName:  20140317_202904.jpg
Size:  88.1 KBName:  20140317_202908.jpg
Old 03-17-2014, 05:54 PM
  #24
Very Nice..... Bent fins happen..... Here is how you fix kinds take care of that...
http://www.summitracing.com/parts/su...Fc9AMgodchQA5w
Hope the one tube is not an issue.... :O
Old 03-17-2014, 06:00 PM
  #25
mrzods13's Avatar
Yea me either, I noticed that when I got it hopefully the coolant will flow properly, thats the only area.
Old 03-17-2014, 06:03 PM
  #26
Old 03-17-2014, 06:07 PM
  #27
mrzods13's Avatar
Think it will be a problem?
Old 03-17-2014, 09:46 PM
  #28
JUst pressure test it.... If it holds.... Its good to go...
Old 03-18-2014, 05:00 AM
  #29
mrzods13's Avatar
Took it to a radiator shop to get pressure tested, not holding pressure, returning it to Charlie.
Old 03-18-2014, 09:06 AM
  #30
Good Call.....
Quick Reply: 22" to 26" radiator
