22" to 26" radiator
22" to 26" radiator
I am most likely buying a new aluminum radiator for my 1968 chrysler newport with the 383 non ac. I have a 22 inch in there now and the one I want is 26" and it is made in usa not china. My question is will I need a different radiator support I am wondering if the 26" will fit.
If it's a crossflow (most aluminum rads are) the core will still be close to 22" and your support won't hinder airflow. The stock mounts will likely not work, but I'll bet you can fab something up no prob.
mrzods13 (03-06-2014)
Call Charlie...
aluminum radiators
I have priced all the aluminum radiators @ 365.00 + shipping, A-B-C-E mopars, small or big block engines.
Transmission cooler is built in just like the factory radiators, and there are brackets built in for the fan schrod.
Please feel free to call me @ 727-271-5068
MOPAR CHARLIE
7 days a week 9am-6pm
located in sunny florida
thanks for the replys, and thanks for the ad
aluminum radiators
MOPAR CHARLIE
He said the driver side will bolt right on, so all I have to do is make new holes for the passenger side and get the clips the bolts screw into. Also i was looking at electric fans, would one 16 inch fan be enough or should I do 2 12's, I don't think 2 14's will fit at a diagonal angle. I have seen Zirgo and flexalite brands.
I'm Not a big fan of electric fans... In some cases you must use them, but I like The good old Mopar Viscous Fan....
http://chucker54.stores.yahoo.net/viscousfan.html
I was looking at these from summit but I don't know if I could fit them both on the 26",maybe diagonal.
http://www.ebay.com/itm/2-Flex-a-lit...9bd2f0&vxp=mtr
On the ones I do Run a fan on... I like to add this controller...
http://www.flex-a-lite.com/accessori...ontroller.html
mrzods13 (03-07-2014)
I was looking at this fan http://www.jegs.com/i/JEGS+Performan...2110K/10002/-1
#24
Very Nice..... Bent fins happen..... Here is how you fix kinds take care of that...
http://www.summitracing.com/parts/su...Fc9AMgodchQA5w
Hope the one tube is not an issue.... :O
