318 5.2l starting problems... please help
Old 10-04-2009, 05:57 AM
MrOldart2U's Avatar
For me for some reason the issues I've had as far as connections go on Mopars has been the battery to body ground... its very critical on Chrysler products... check it first.
Old 10-04-2009, 10:01 AM
scotts74birds's Avatar
X2 on everything. Get a manual and start checking things. You dont learn anything by throwing parts at a problem. The satisfaction of a cheap repair is its own reward. My95 Ram 5.2 would do the same thing. The solenoid on the starter would get filled with moisture and corrosion. I took it apart and cleaned and sanded the contacts, applied dialectric grease to the contacts, and it has served me for 2 years with no problems.
Old 02-03-2011, 09:05 PM
Foedoe's Avatar
Pop the hood and watch the positive battery terminal when you start it if it sparks then take it off redo the connection and tighten mine does that sometimes
xvodysseusvx
06-25-2018 04:38 PM
Ratt Dawg Ralph
08-22-2011 03:44 PM
prive81
08-03-2010 06:50 AM
alsparl
07-07-2009 03:39 AM
Evnas
04-13-2009 11:01 PM
Quick Reply: 318 5.2l starting problems... please help
