ignition problem
Old 05-12-2009, 12:16 PM
Polaradude's Avatar
Check your grounds. Could it be a bad/worn ign switch ?
welcome to the forum.
Old 05-12-2009, 03:47 PM
welcome
i'd re-trace all wires
Old 05-13-2009, 02:38 PM
Polaradude's Avatar
For sure ground the ecu...check yer grounds dude.
Old 05-13-2009, 02:44 PM
scotts74birds's Avatar
No, batt voltage would not damage the coil if only used briefly for troubleshooting
Old 05-13-2009, 02:47 PM
Little Demon
Red Devil's Avatar
I see you are in Milwaukee, so am I, welcome aboard
Old 05-14-2009, 11:22 PM
K, Glad we proved we can mak it run! Im an electrician but the mopars of the 79 era have me fuzzy. Do not know what of the old tech they used and what of the new stuff they used. If they were still using ballasts in 79 then the coil wants 7-8 volts while running, The ballasts ould take the voltage of 13.2 avg and dissipate that, through heat to 7-8 volt. Have you tested the ballast resistor?
Plymth74Dstr
12-21-2013 07:17 AM
a.johansson84
05-27-2012 03:30 AM
Tiretrack
07-10-2010 08:14 PM
jdewoskin
06-08-2010 04:14 PM
GMdude
07-09-2009 04:42 PM
Quick Reply: ignition problem
