Mapping my DIY Electronic Ignition :)
Old 09-25-2012, 11:06 PM
1966DartConvertible's Avatar
Got my distributor fixed, now mapping the ignition timing vs. RPM vs. load using the handheld trigger.
I can retard/advance the ignition timing at every 300rpm increments (or 500rpm increment if you wish) (15 steps i.e. 0 - 4500rpm) vs. load (throttle). Here is a picture or two :
and here ive also fitted the 3-3/8" Sun Pro Tacho on the column (can't fit on top, no clearance)
Syed
Malaysia
Old 10-27-2012, 05:55 PM
PK1
PK1's Avatar
Excellent post!! Did you do / make that yourself or are you using a specific part in a custom application? If it's the latter could you tell me what part / parts you are using?
That is a great looking car!
catchmeifyoucan
07-22-2014 06:17 PM
1966DartConvertible
05-13-2012 08:11 PM
tish
10-20-2008 05:43 PM
318dart
05-20-2008 12:14 AM
theaspenator
01-30-2008 06:30 PM
Quick Reply: Mapping my DIY Electronic Ignition :)
