Voltage range for points
Old 07-16-2017, 05:00 PM
demetri's Avatar
My 68 is acting up again, and I am suspecting excessive voltage. I was getting 14.7-14.8 V at around 1500 rpm yesterday. Later, I was at 14.4. Power windows etc seemed to move faster than usual. I think this may be excessive, and may be frying the points. Any knowledge of what the maximum voltage should be? I thought around 14V is about right.
Thanks
Old 07-16-2017, 05:35 PM
Over 15.0 volts and your in trouble...
Check Grounds...
The regulator might be no good.
Old 07-16-2017, 05:49 PM
demetri's Avatar
Check Grounds...
Thanks. I had replaced the regulator recently for the same reason, excessive voltage, frying points. Unfortunately, the diagnosis was not easy, and I got stranded at least once. Now, it may be happening again.
But you are suggesting that 15.0 volts is the trouble, 14.8 is ... OK?
Old 07-17-2017, 01:16 PM
At 14.8... That would be a crap shoot.... Trust your meter or call it defective.. Me.. I would call it defective and get a new regulator. Make sure the grounds throughout the car are all in good shape.
As for the point Burn issue.... That to me would lead me back to a ballast resistor problem or just plan cheaply manufactured parts maybe.
Just my point of view,,,
Old 07-17-2017, 05:02 PM
fivepoint's Avatar
Check the voltage on each side of the ballast resistor. I think ideal voltage on the coil side of the resistor is around 9 volts. When you change your points, be sure to change the condenser too.
68satellite
02-13-2022 06:58 AM
Undertakerman
02-08-2016 02:13 PM
72 plymouth
08-08-2010 12:02 AM
68 Sat
11-11-2008 11:05 AM
rick_wa
07-13-2008 01:27 PM
Quick Reply: Voltage range for points
