318 pushrods
318 pushrods
I change the cam of my 318 to a one with more lift and duration( hydraulic). When I tried to install the valvetrain (the stock 1.5) I notice that I will need a larger set of pushrods. A friend told me that a set of adjustable pushrods will work.Another friend don't recomend me the use of adjustable,but he don,t know the true reason. I may go for a set of adjustable rocker arms, but this is a more expensive solution. Please I accept recomendations for this issue.Thanks
318 pushrods
Yes, this is another way, but where I can find the pushrods in the exact lenght? Have suggestions?Thanks for the advise Crazy4Carz.
318 pusrods
Thank's Crazy4Carz, first I'm going to find a pushrod lenght checker and later I will try Summit or Jeggs.The stock pushrod lenght is 7.5", I think I will need something near 7.58"
318 pushrods
I'm not sure,I need to find a pushrod lenght checker first to go by the book. The stock lenght of the pushrods is 7.5",maybe I will need something near 7.58" or 7.6" The set that you have what lenght are? Thank Ellis.
A.K.A Bob Dodge
on
odd, i never ran into a problem with changing cams, never had a pushrod issue,
did you run it like that or just bolted them down and they were a lil loose.
69POLARA383
06-26-2012 05:31 PM
