Sponsored by:
Sponsored by:
440 not firing after its warmed up
Old 10-04-2012, 12:26 PM
1923tbucket's Avatar
Just as it said, for instance i'll go get gas, shut the car off pump fuel and boom it wont fire. I dont understand it ive never had this issue. Ive never done the cap and rotor on it, possibly this is a good bet?
Old 10-04-2012, 05:25 PM
How 'bout some more info. What is this we are working on, what is the engine combo, and what EXACTLY are you running for ignition?
What do you do to get it started? Cool off? Crank some more? Tow it home and hope?
Have you checked for spark when this happens?
You getting fuel to the ???carb??? efi?? what???
Old 10-04-2012, 10:56 PM
Chryco Psycho's Avatar
have you checked the reluctor to pick up gap in the dist , it should be .008
Old 10-06-2012, 08:01 AM
Yea sorry I didn't provide a lot. It's a 440 6 pack carb setup with a Mallory points distributor. I pulled the cap and the distributor rotor and the cap looked a little rough so I'm thinking it's that. The car is sold though, the new owner is aware. It's been such a fun car and I'll miss it.
Old 10-06-2012, 01:42 PM
Points type dist -- Change the condenser too !
Old 05-31-2015, 08:53 PM
usaf46270's Avatar
loss of fire
that was the first thing I would change, then the ballast resistor
Old 06-01-2015, 08:08 AM
DDodger's Avatar
Very first thing I'd do is check the spark. Buy yourself a spark tester. Lisle makes one that's not very expensive. See if it actually has spark or not when quit. "Might" be fuel boiling instead, flooding
MReeves
Cuda Specific Discussion
13
04-28-2014 07:46 PM
Fabulous61Fury
04-09-2012 08:57 AM
Zach8200
03-24-2011 04:11 PM
Mopar_71
08-23-2010 04:41 AM
Barfly
04-29-2010 08:55 PM
Quick Reply: 440 not firing after its warmed up
