Sponsored by:
Sponsored by:
Engine Identification
Old 04-18-2009, 11:55 PM
sgp7679's Avatar
Question Engine Identification
How can I tell what engine I have? Im pretty sure its a 318 but I want to know for sure. I looked everywhere for a vin but theres no markings on the engine anywhere. Not even firing order or timing marks.its rear distributed.
Old 04-19-2009, 01:24 AM
theomahamoparguy's Avatar
there should be numbers cast [stamped?] into the side of the block on the A motors.
They are in the vicinity of the core plugs [above them i believe]
They should be located on the left side, just below the cylinder head.
If it is the original 65 motor and is a polysphere, then it will be a 318 because the 273 motors were not polysphere motors,
Number should read something like "A-318-1-8.."
Old 04-19-2009, 03:19 AM
Polaradude's Avatar
If it's the original motor in the car the first digit on the door post tag will tell ya. If its a 4 than its a slant six coronet, if its a w than its a v8 coronet in 65.
But like omaha says the numbers should be where he says they are or just above the oil pan rail on the block on the left hand side. Let us know what ya find.
Old 04-19-2009, 10:08 AM
sgp7679's Avatar
well it has a w and i already knew its a v8, but i want to know what size.
Old 04-19-2009, 10:39 AM
Polaradude's Avatar
Well, like Omaha said, get more #'s.
uponone789
09-28-2012 03:48 AM
528cuda
04-10-2011 06:49 PM
528cuda
04-05-2011 05:09 PM
StealthTT
03-03-2011 10:02 AM
ramsterhemi
06-03-2008 02:35 PM
Quick Reply: Engine Identification
