Header Bolt Issues
Header Bolt Issues
I have a 360 Magnum in my 37 Plymouth Coupe and have an issue with the header bolts coming loose over time. Have to tighten them every few hundred miles. Using ARP stainless bolts and the washers that came with them.
This is my first Magnum all other Mopar V8s have been big blocks or LAs. Is this a common issue with the Magnums?
What type of gasket are you using?
They don't leak but they compress forever. But that's what I was looking for.
These kick azz if you have bolts that vibrate loose all the time>>>>> https://www.lawsonproducts.com/Nord-...Steel/58098.lp
But if its just the gasket keeps crushing.... Thats a whole other issue
You can try them but IMO it just takes finding the crush limits of the gaskets.
Skynyrd
08-22-2014 05:24 AM
