Go Back   Mopar Forums > GENERAL > General Discussion
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 11-17-2007, 10:40 PM   #1 (permalink)
bgreene30
Junior Member
Send a message via AIM to bgreene30
Question Header Recommendations?
Hi everyone.
I have have a car with a 440 magnum HP motor and have been thinking of putting headers on it but there sure doesn't seem to be much room in that engine compartment of my Satellite.
Any suggestions on ones that you have done and fit ok without MAJOR mods or headaches installing? All my other cars have Dougs headers but I just can't see them fitting.
thanks and happy early turkey day!!
Bobby
bgreene30 is offline   Reply With Quote
Old 11-18-2007, 10:37 AM   #2 (permalink)
440roadrunner
Senior Member
What year? The early 65 and earlier bodies are a real problem. The '66-later should be no problem if you order the proper headers for the engine/body combo. The two later B bodies I owned were 69 and 70, and it's been awhile. Seems to me that you did have to jack up the engine a little bit on one side, probably remove the starter when slipping the headers in there.
What I'm saying is, you may need to juggle a few things, but you won't have to hack up the body and you won't have to pull the engine out.
Different brands of headers will fit different, and whill have their own individual problems with plug wire routing, etc. On my '70, which had Cyclone headers back then, I welded up a special wrench for one rear plug. Even that was only needed for the strip, when the engine was hot. I could change plugs quite easily when the engine was cold.
440roadrunner is offline   Reply With Quote
Old 11-23-2007, 09:08 PM   #3 (permalink)
bgreene30
Junior Member
Thanks for the info. It's a 1968 plymouth satelite.
Bobby
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Header Recommendations bgreene30 B-Body 3 09-01-2008 01:40 PM
Header recommendations bgreene30 General Technical Questions 0 11-17-2007 10:39 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
