Sponsored by:
Sponsored by:
Mopar Performance Ignition
Old 02-26-2009, 07:58 PM
thinkin with me dipstick
johnthegoalie's Avatar
sounds like when i converted over to electronic - turns out the magnetic pickup piece - the actual piece with the wires was defective. turns out it is a real common part.
Old 02-27-2009, 02:02 AM
Do you know that it is not getting spark? I would check your timing as well.
Old 02-27-2009, 02:30 AM
Polaradude's Avatar
Ya I agree with Tim, if shes burpin' back through the carb it sounds like plug wires are mixed up or timing.
Old 02-27-2009, 05:27 AM
Did you pull a plug to see if there was fuel on it? If so, with what you just said, it sounds to me like you've got an issue (bad wire) with the wire going to the ballast resistor. Or the ballast could be restricting the power going through and you need extra to push it through.
Follow the wire that goes into the ballast and see where it leads. You may find your problem along the way.
Old 02-28-2009, 11:58 AM
Polaradude's Avatar
Cool, thanks for the info, never heard of that before.
Old 02-28-2009, 12:22 PM
good research hemi! THats great to know for people that could have the same problem in the future .
68Dart
03-17-2019 05:43 PM
aatkinsonalexdatkinson
08-24-2014 11:06 AM
a.johansson84
05-27-2012 03:30 AM
Tiretrack
07-10-2010 08:14 PM
GMdude
07-09-2009 04:42 PM
Quick Reply: Mopar Performance Ignition
