Retrofit roller lifters
Old 10-05-2010, 12:16 PM
69POLARA383's Avatar
Hello all, wanting to go to a roller lifter on my purple shaft, hydro flat tappet cam, any drawbacks or extra work needed to run, or is it even possible? Have 1.6 steel roller rockers, should I go hydro or solid lifter? Running 100-200 nitrous as well. Havn't bought push rods yet so not a prolem there yet.
Old 10-05-2010, 07:20 PM
A.K.A Bob Dodge
1966sportfury's Avatar
theres nothing to worry about putting rollor lifters in, drop in deal, cam hydr or solid both are good if its going to be a track queen then id go solid, if street drivin quite a bit then i would go hyd,
Old 10-06-2010, 01:56 PM
A.K.A Bob Dodge
i thought he was talking about using a hydrolic or solid rollor cam,
i missed that part i just skim read it
Old 10-06-2010, 02:40 PM
I run a roller cam in my 440 Dart....the cam is made from billet steel...you must use a roller cam with roller lifters...a bronze distributor gear and if a big block a bronze tip fuel pushrod...either hydraulic or solid....hydraulic for street...solid for track and 200 shot....M2C..no roller lifters on purple shaft cams
Old 10-06-2010, 02:59 PM
ok. thanks a bunch guys, the roller cam itself is only another 100-150 so def go for the roller cam/lifter kit.
Old 10-06-2010, 03:02 PM
The cam should be 300.00 and good set of roller lifters 500.00 and a good set of adjustable rockers 500.00...its no cheap but these are what you need...Eric
Old 10-06-2010, 06:02 PM
Thought of something else... I have 1.6 ratio roller rockers, I'm not sure if I have reliefs cut into my piston heads for the kind of valve lift I want on a new cam. Is there a way to look up the head specs without removing it since I can not do it myself and cant contact the original owner anymore? Or should I stick with the purple shaft and hyd flat tappet with the roller rockers so I dont destroy my valves? This is the most confusing part of the freakin motor?!?!?
maca
04-17-2015 08:02 PM
maca
07-17-2014 03:13 PM
maca
07-10-2014 08:21 PM
Arbiter343GS
10-24-2012 02:54 PM
Erikthegoalie
02-09-2009 03:34 PM
Quick Reply: Retrofit roller lifters
