Sponsored by:
Sponsored by:
valve stem seals
Old 10-28-2010, 08:53 PM
timmie124's Avatar
valve stem seals
so i started to rebuild my heads tonight and i opened up my engine rebuilt kit and noticed there were 2 different styles of valve stem seals one was short and stubby the other was longer which one is for the exhaust and witch one for the intake? ones like a rubber the other is a hard plastic it came with 8 of each
Old 12-19-2012, 10:34 PM
3.6rs's Avatar
Does anyone has an answer on this ?
Wich one is for the exhaust and wich one for the intake ?
Thanks
Old 12-20-2012, 08:09 AM
Chryco Psycho's Avatar
the positive seal should go on the intake , 1 you do not want oil contamination in the incoming air flow & 2 the intake runs cooler & needs less lubrication & 3 you have vacuum around the intake valve , the umbrella is exhaust , the valve is subjected to more heat , expands more & is under pressure
The following 2 users liked this post by Chryco Psycho:
3.6rs (12-21-2012), John Highway (10-14-2022)
Old 12-20-2012, 11:08 AM
Gorts 5th's Avatar
Smile
what about the after market seal's? mine where unlike both of those they where more like the intake valve seal only longer a comp cams seal set.
Old 12-21-2012, 03:23 AM
3.6rs's Avatar
Like this one ?
Old 12-21-2012, 08:33 PM
Gorts 5th's Avatar
Originally Posted by 3.6rs
Like this one ?
similar but not exactly.
but it looks very dependable.
Old 12-21-2012, 08:51 PM
You can use a positive seal on both valves as pictured above
Old 12-21-2012, 11:21 PM
3.6rs's Avatar
And what about valve stem seals where "the valve guides needs machining" ? What kind of seals are these ?
Old 12-22-2012, 03:46 AM
To use the PC seals usually the valve guide needs to be machined for them
Old 12-22-2012, 04:33 AM
the factory type posititve seals in the pix do not need the guide machined down , the aftermarket seals are usually smaller diameter to fit inside dual or tripe springs & do require the guide to be machined down , usually at the point where you go to dual springs the lift on the cam is enough that the guide needs to be shortened as well
Old 10-14-2022, 04:50 PM
John Highway's Avatar
Valve stem seal selection
Old 10-14-2022, 04:56 PM
Please bare with me, Ive never been on a forum before ever.
my intention is to ask more about these seals. I have a Fel-Pro kit containing 3 different styles of valve seals with 8 of each style. I would ask from left to right, which seal is the appropriate for which valve? Thank s for your time and guidance.
Old 10-14-2022, 09:16 PM
Welcome to the forum, sorry I can't help with the seals I haven't used stock type seals in forty years so I'm rusty...
Next time start your own thread with your questions, thanks.
Old 10-15-2022, 02:08 PM
The left two are options for the intake valve and the far right one is for the exhaust valve.... Most folks now use a newer style valve stem seal...
Welcome to the site... and like Iowan said, you can start your own trend and get more newer response's. Cheers
74Runneer
10-17-2015 10:32 AM
rookie440
01-13-2013 06:37 AM
jpnavy
02-07-2010 09:13 AM
deadkelly
03-10-2009 10:15 PM
Quick Reply: valve stem seals
