1971 charger. Help!
Old 08-21-2012, 04:57 AM
1971 StreetMachine's Avatar
Exclamation 1971 charger. Help!
Ok so I am 15 I am building my first car. here is the problem, I have moved the shifter from the steering collom to the floor, we yesterday the linkage cable from the b&m shifter (which was wrapped in 3 layers of heat proof materials) had melted. Now here is the questions, what am is doing wrong and/or what can I do different? Please and thanks
Old 08-21-2012, 06:08 AM
Archer's Avatar
71 -
You let the cable get too close to the exhaust. If you can't route it away from the exhaust pipes/headers, you may have to buy or make a shorter cable.
Old 08-23-2012, 04:23 AM
Well I feel if I go any shorter the cable will bind.
Old 08-25-2012, 07:35 AM
BuckNeccid's Avatar
If I have time I'll measure my cable, but pretty sure it's a 42" cable. It's really important to route your cable away from the headers.
Another option is to hit e-bay and look around. They sell spark plug protective sleeve material in different diameters, and in rolls. You might find some in like a 1/2-3/4 diameter, and instead of cutting it to protect your plugs, use a long piece to cover your cable housing and again, think about your routing and route it away from the headers. Wire ties or even bread ties to keep it in place. Think outside the box
http://www.ebay.com/itm/DEI-Protect-...#ht_956wt_1188
Old 08-25-2012, 03:36 PM
Gorts 5th's Avatar
Smile
I RUN MINE DOWN OVER THE TOP DOWN THE RIGHT SIDE OF THE TRANY BETWEEN THE DIPSTICK TUBE AND TRANY BODY AROUND THE FRONT UP THE LEFT SIDE TO THE SELECTOR
I USED THE 36 INCH B&M CABLE
GIVES ME PLENTY OF ROOM AROUND THE HEADERS AND THE PIPES
SteveRT
08-17-2010 04:31 AM
DUCMAN166
12-21-2008 07:49 AM
Mopar71
09-24-2008 09:17 AM
7200liter
06-16-2008 02:08 AM
71charger
04-02-2008 05:22 AM
Quick Reply: 1971 charger. Help!
