Non-Mopar Tech Questions Want to ask our knowledgeable group here at MF a question about a non-Mopar? This is your place!!
anybody know anything about honda 4 wheelers?
Old 05-08-2009, 09:00 PM
Go see a Honda dealer. I hate saying it but it is true.
Old 05-09-2009, 11:57 AM
Polaradude's Avatar
Are you saying water got in the fuel tank or it drank water through the carb ? I'll help ya if I can, just need a little more info.
Old 05-09-2009, 08:04 PM
sgp7679's Avatar
1st thing, DONT take it to a dealer. They usually dont work on old models. 2nd because they will rip you off. You said you switched for a 87 to a 89 or something? are you talking about the carb.? Check your jets, make sure their tight. Once my atv was doing that and the jet had fallen out, it will run with the jet out but very bad.
Old 05-10-2009, 03:45 AM
Polaradude's Avatar
or there is crap in a circuit of the carb.
Old 09-30-2009, 08:27 PM
MrOldart2U's Avatar
Im no 4 wheeler expert but sounds to me like the float level is to high...
Old 12-14-2009, 11:36 PM
deadkelly's Avatar
Originally Posted by ryan_e
alright i got an 86 honda trx 125 four wheeler and when i got it the carb only had one bolt in it so i tore it apart put a new gasket on it, put new bolts in it, and put it back together but alot of water got into the tank. i drain as much as i possibly could out of it and put 87 octane in it, then it never wanted to run. i just put a new plug in it cause there was nothing left and i swaped the 87(had a lot of gunk in it) and put 89 in it. now it runs off and on, you can give it hell one minute and itll haul *** but then it just boggs down and it almost sounds like its not gettin enough air but im not sure. any suggestions?
try fuel filter , pull ya carb off again & fuel bowl . & give it another clean out . when you drain your fuel tank ( take the tank off ) ya should shake it around with metho ( metholated spirits ) get out all the metho & air dry . clean ya coil wires & make sure ya spark plug boot is clean & on tight . how is your air cleaner is it new ? if crappy replace . is there water in the air box ??
RowdyBurns
11-07-2013 07:38 PM
DustinHeck
10-15-2013 01:21 PM
gibson279
04-24-2011 10:46 AM
sammy9015
01-24-2011 04:54 PM
66dartvert
04-03-2008 06:00 PM
Quick Reply: anybody know anything about honda 4 wheelers?
