440 vibration in neutral
Old 02-04-2009, 10:42 AM
Commando's Avatar
Your problem has to do with how the engine is balanced. If you have a steel crank the engine is internally balanced and requires no weights on the dampener or torque converter.
If you have a cast crank the engine is externally balanced and requires weights on the converter and dampener.
It sounds like you have an internally balanced engine with external weights. If you get a neutral balancer converter, and the right dampener you should be fine.
Old 02-04-2009, 11:36 AM
I've seen and heard of even more reman long and short blocks not being rebuilt right. I'd try what Commando said. If it still happens then you may have to tear down the motor and have the rotating assembaly balanced properly.
Old 02-04-2009, 08:00 PM
Commando's Avatar
I was just relying on the fact that it was done properly, I hope its as easy as I said. Good Luck!
Old 02-05-2009, 02:31 AM
Commando's Avatar
Where are you located at, I have a cast crank lying around if that is the route you choose. Not near by it, but I could get you the part numbers in about two weeks.
mcatwood
07-29-2013 02:15 AM
maca
08-21-2012 06:17 AM
Drakovich
11-28-2011 04:17 PM
chezhed
07-18-2011 03:11 AM
c011699
04-11-2010 03:27 PM
Quick Reply: 440 vibration in neutral
